Brake Specifications for 2001?
Anyone happen to have the brake specifications on the 2001 L? I was doing an inspection on my truck in school and the Brake Specifications Guide didn't mention the SVT. I had to guess and used the specs for an F-180 (whatever that is) because it had front and rear discs and 14mm lugstuds. Does the 2001 l have 14mm lugstuds and am I using the correct specs for this truck?
Any help would be great as I am doing another inpection on Monday. Doom |
Are you asking about the torque value for the lug nuts? If so, I believe the factory spec is 140 ft. lbs. but I only torque my 01's to 110 ft. lbs.
Dan |
140 lb! Torque them to full factory specs, cause i didnt once and a bolt came off while braking!
I am asking for all specs for the brakes. Wheel torque, caliper torque, bracket torque, runout, machine limit, parallelism, discard, nominal and pad limit.
fronts are the same as an f250 and the rears are stock f-150 brakes.
