F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   Those of you running LFP's electric fan... (https://www.f150online.com/forums/lightning/172320-those-you-running-lfps-electric-fan.html)
2000Black Oct 20, 2004 11:11 AM
Were you able to keep your stock water pump and run the LFP fan kit? I have done a search and the results are inconclusive. Thanks!
Don's Bolt Oct 20, 2004 11:19 AM
From what I have heard it is the same as the JDM kit. If so yes you can use the stock water pump.
00Bolt Oct 20, 2004 11:30 AM
i have JDM efan and my stock waterpump... i heard it was a waist of money for the cobra R pump....
ShadowBolt Oct 20, 2004 11:48 AM
LFP e-fan and stock water pump works great together.
Jerry
ICULOKN Oct 20, 2004 12:41 PM
You can get alittle better flow out of the Cobra R pump. The impellers are differant. Plus its made for no fan attachment and wont have threads showing.
Fear Itself Oct 20, 2004 01:38 PM
Actually, I think the "Cobra" water pump flows slightly less than the stock water pump, its advantage is that it takes less horsepower to turn.
I have the LFP E-fan and retained the stock water pump with no problems.
David
soap Oct 20, 2004 03:35 PM
Sure hope WOT doesn't see this.............
--Joe
Speedin Bob Oct 20, 2004 03:54 PM
With all due respect, the first sentense is incorrect. The second and third statements are correct.
http://imprint.uwaterloo.ca/issues/1...ay/image05.jpg
~nightcrawler~ Oct 20, 2004 08:27 PM
LFP E-Fan and stock water pump here. I have a 2003 so the impeller design is the same as the Cobra R, but with bigger impellers...so does that mean it flows more...hmmm
So unless you just want to spend money for the "cobra R" pump that doesn't have the fan threads on the end, frees up a couple HP, and flows less...then the stock pump will work just fine:thumbsup:
cpeapea Oct 20, 2004 08:55 PM
ive heard a lot of conflicting advice on the water pumps, i dont think that anyone has really pointed out a solid gain with one to me. that doesnt mean there isnt one, just one that i havent personally seen first hand. i remember someone reported a loss with one, but there was no proof with that either
Nuhklz Oct 20, 2004 10:18 PM
Re: Those of you running LFP's electric fan...
Yes:thumbsup:
