Traction Bar differences
Originally posted by brain bypass
i doubt it. i have a magnaflow cat back, and i have a couple inches of clearance. i am lowered in the rear with 3" shackles.
Nobody digs Cal-traks?? Hmmm.
Well let me be the first. My truck is lowered 2", I have aftermarket exhaust and there's no clearance issues. they're not noisy, like some people complain and they work well. I am biased because I run them on my Mustang too. Cal Traks all the way!
Flord,
What 'level' are you at with your truck? What's your combo and track times? Got any install pics?
I'm trying to put all of the real world feedback into the proper perspective for my plans.
Thanks,
Herb
Thanks,
Herb
That's kind of what I'm leaning toward.
It sounds like the only real negatives would be exhaust clearance on some catback and possible speed bump food for the front brackets.
If I fab them, I will most likely use hiem joints at at least one (front) end. This make cause some noise, but its not like my truck is quite anyway... save that junk for the Caddies.
Later,
Herb
Later,
Herb
Originally posted by 35thPony
good to know... how easy are these to install... what tools will I need.
-jack
-jackstands
-some assorted deep sockets
-18" breaker bar
-ft-lb torque wrench
-1/2" drive socket (you could use a 3/8", but my larger sockets are 1/2")
-drill w/ a bit i had to shorten to drill the hole in the side of the frame, but a 90* drill would make it easier
