Couldn't let Tim have all the fun. :)
Changed my calipers now, I've gone red... Tim's looked so good, I had to copy. :) lol... bye-bye black Brembos, hello red Brembos.
http://www.atlantis.edu/~thepawn/ima...brembo_800.jpg Had to make the rear match: http://www.atlantis.edu/~thepawn/ima...aliper_800.jpg Its "curing" overnight (this brush on caliper paint rocks), I'll take another shot of it tomrrow in the sunlight. --Daniel |
nice
Sweet :thumbsup: :thumbsup:
:drool: :drool: :drool:
What brand caliper paint did you use? I want to do my stock ones and the brush-on kind seems the easiest to apply...
"pretty", IT ROCKS!!!:bows: Actually, im not bowing over the color, Im drooling over your brakes in general.:drool:
Originally posted by LightningGuy What brand caliper paint did you use? I want to do my stock ones and the brush-on kind seems the easiest to apply... High gloss enamel paint...turns rock hard in about 4 hours. :) --Daniel |
Niiiiiiiiiiiiiiiiice Pawn :thumbsup: :thumbsup:
Originally posted by AmoJohnny "pretty", IT ROCKS!!!:bows: Actually, im not bowing over the color, Im drooling over your brakes in general.:drool: I've moved up to slotted rotors from cross-drilled this time around...not quite as bling, but more set for racing. Daniel |
thepawn:
Do you have a mildly used set of dimpled/fire-slotted rotors for sale or are you talking about an old Brembo big brake kit? I'm looking for the former so if you have a set available, please let me know! Also, what procedure did you take to apply the brake paint? Did you tape off everything or was the brush-on method easy enough to do safely without blocking everything off? |
Originally posted by LightningGuy thepawn: Do you have a mildly used set of dimpled/fire-slotted rotors for sale or are you talking about an old Brembo big brake kit? I'm looking for the former so if you have a set available, please let me know! Also, what procedure did you take to apply the brake paint? Did you tape off everything or was the brush-on method easy enough to do safely without blocking everything off? I only taped off the rear rotor a bit and one of the plates on the caliper as well as the brake line and bleeder valve...in hind site, I should have taped off the screw mounts too (got a little paint on them), but overall the paint was pretty easy to work with.... the hardest part was figuring how much of the caliper mount I wanted to matching paint, since a piece of it is visible... Daniel |
Originally posted by thepawn My old brembo big brake kit is for sale ... Daniel and Expiditions?????? < DROOL > I want that extra inch of torque soooooo badly .... |
Originally posted by SVT_KY How come? Did you get the new 15" kit for the Excursions and Expiditions?????? < DROOL > I want that extra inch of torque soooooo badly .... --Daniel |
SWeet :rocker:
Those look awesome!
| All times are GMT -4. The time now is 09:14 PM. |
