alignment issues
Old Jun 4, 2004 | 05:03 PM
brain bypass's Avatar
alignment issues
i just got new f1s for the front a few days ago, i noticed that the old ones had some wear on the inside, and the truck would pull to the right. so i went to my dealer to get an alignment, and the service guy told me that i needed some sort of $180 shims to for them to do it. he said that the trucks come from the factory without enough adjustability to set it. the front suspension is completely stock. he said that they have to do it to 99% of the trucks they do.
this makes zero sense to me. anybody have any issues getting an alignment?
Old Jun 4, 2004 | 05:07 PM
Fear Itself's Avatar
They are talking about replacing the shims with cam bolts. You can buy them for less than $30 and install them in less than an hour.
Do a search for cam bolts and you will be rewarded with a multitude of information and how-to's.
David
Old Jun 4, 2004 | 05:13 PM
i guess the proce of $180 is including labor?
i knew about the cam bolts, but he didn't mention those.
thanks!
Old Jun 4, 2004 | 05:16 PM
Unless they're gold-plated!
Old Jun 4, 2004 | 05:21 PM
AmoJohnny's Avatar
They told me the same EXACT thing. Only on the left side, and they did install the cam kit.
Old Jun 4, 2004 | 08:37 PM
Harley#356's Avatar
like said above, pick up a set of camberbolts (only need one for each side, put it in the rearward upper A-arm mount) for like 30 bucks, then go get it alighned at a shop. places that do alot of collision repair usually do it pretty cheap since they are doing them so often. when i did my 1" front drop i put the camber bolts in myself and had an alignment done for 40 bucks
Old Jun 4, 2004 | 09:42 PM
EZGZ's Avatar
intersting.
My 99 is stock. I only adjusted the cam bolts on both front units and when replacing the rears added the cam bolts but left the shims in.
agree with everyone else's comments
Old Jun 4, 2004 | 09:58 PM
shelpdoggSVT's Avatar
I was told by the shop I just had an alignment done at that I would need to have all 4 of the cam bolts replaced. (up front)
At a price of $170 bucks....told them to take a hike. The inside of the right front tire is worn a little and it seems to pull to the left....(go figure).
I was going to ask Konig (you out there ???) if there is a shop in Tampa/St. Pete that he can suggest, because I think these guys don't have a clue as to what they were doing.
If you can put them in yourself....I'm game.
Old Jun 4, 2004 | 10:02 PM
Harley#356's Avatar
https://www.f150online.com/forums/sh...ght=step+roush
if you weren't sure exactly how to swap the bolts out for camber bolts, check out the how-to in that thread.
if you aren't dropped, or dropped up to 1" you only need 2 camber bolts, one for each side, and that will allow enough adjustment you need for camber to put you where you need to be to wear evenly and not pull to any sides.
if you are dropped more than 1" up front though probably a good idea to get 2 for each side.
Old Jun 5, 2004 | 02:46 PM
#18 of 6381's Avatar
I had a flat a month or so ago.
Took it to the first open place that could fix it so i could get to work as early as poss.
I found out that due to the no adjustment/cam bolt prob. I ended
up paying for 2 new tires and a trip to install the cam bolts.
Along with the rental car the total on my flat was about 800.00
Old Jun 5, 2004 | 03:07 PM
SVT_KY's Avatar
Do yourself a favor and get the beefy ford camber
bolts. The aftermarket ones wouldn't hold on
my truck. Spent two sets of tires learning that ....
Old Jun 5, 2004 | 03:09 PM
SVT_KY's Avatar
You will need all four to adjust the camber correctly ...
Camber is the vertical side to side component, and
both of the top bolts need to be adjusted to set it.
Old Jun 5, 2004 | 06:29 PM
Harley#356's Avatar
i only have 2 and all the alignment specs are right on. i stood there and watched the entire time so i know he wasn't just BSing me either
Old Jun 7, 2004 | 11:37 AM
does anybody have the ford part number? i will probably do all 4 since i plan to lower 1.5" with ruslow spings eventually.
Old Jun 7, 2004 | 12:02 PM
builtfordfast's Avatar
Cam bolts(OEM).....F65Z-3B236-BB
Cams.....................F65Z-3C1788-AA
Photo Gallery......................Website.......................Modifications
Have a great day eh !................................................. .....Dave
