Knock Sensor
Old May 28, 2004 | 02:04 PM
JimJr's Avatar
Knock Sensor
Why couldnt the Lightning use a knock sensor? Reason i ask is i just installed a new 306 into my mustang and got the optional knock sensor because i run a vortech on it. wouldnt it be benefitial incase you do detonate? Just a thought.
Old May 28, 2004 | 02:43 PM
MaxPower's Avatar
They're diabled on our engines due to the engine and blower and additional noise it introduces...
...at least that's what I've read on here. I know a search will reveal that as well.
Old May 28, 2004 | 03:31 PM
wydopnthrtl's Avatar
Do the 03+ cobras have one?
Rich
Old May 28, 2004 | 05:53 PM
JimJr's Avatar
i wouldnt see how noise would be a problem...we "deal" with S/C Whine but the whole point is so it dosnt detonate....i could live with some noise for that peace of mind
Old May 28, 2004 | 07:02 PM
cpeapea's Avatar
the blower sets off the knock sensor and retards the timing
Old May 28, 2004 | 07:16 PM
grinomyte's Avatar
i'm pretty sure that all ford truck 5.4's and 4.6's don't come with knock sensors.
Old May 28, 2004 | 07:18 PM
cpeapea's Avatar
sure they do, its underneath the intake in the valley
Old May 28, 2004 | 07:28 PM
grinomyte's Avatar
ohhhh is that what that is? Its near the front right?
Old May 28, 2004 | 07:32 PM
Suavy's Avatar
Yes they do come with them and yes they are active unless your tuner has deactivated them.
Suavy
Old May 28, 2004 | 08:42 PM
Calightnin's Avatar
Our motors do NOT use the knock sensor. Calling Sal.
Old May 28, 2004 | 08:45 PM
grinomyte's Avatar
while on the phone ask him about the stock n/a engines as well.
Old May 28, 2004 | 09:30 PM
Calightnin's Avatar
Sal says, "KS is not turned on from the factory".
Old May 28, 2004 | 09:43 PM
Tim Skelton's Avatar
I think that mine was deactivated from the factory because of the $&&%( piston slap.
Old May 28, 2004 | 10:12 PM
superfords's Avatar
Originally posted by JimJr
i wouldnt see how noise would be a problem...we "deal" with S/C Whine ....i could live with some noise for that peace of mind
it's not noise that you can hear, it's noise that the sensor can hear.
the sensor "listens" for the sound of spark knock in the engine, apparently the s/c creates noise that interferes with the proper opperation of the sensor.
I believe it is called a peizoelectric sensor, but it's been awhile, so I may be mistaken
yes, they do, here's a picture of one. see it hiding there under that metal coolant tube. it has a bolt holding it into the block:
the "RIGHT" side of the motor is Bank 1 on the passenger side, the "LEFT" side is the driver side. anything being described as left or right on a vehicle or engine is described as viewed from the driver's seat, not as you would see it if you were standing in front of the truck.
there are two sensors on the LEFT side of the motor, one is in front in the timing cover it is the CMP or camshaft position sensor, the one going into the head on the left side under the intake is the CHT or cylinder head temperature sensor. the knock sensor is in the very bottom of the valley, see above pic.
Suavy
You are correct, they do come equipped on Lightnings, however you are wrong about them being "active". Lightnings do not use the knock sensor from the factory.
later,
chris
Old May 28, 2004 | 10:54 PM
Suavy's Avatar
I'm gonna call my SVT Engineer in dearborn Tuesday and see why not.
Superfords, I know your an engine tech but I was told by our dyno techs here at Romeo Engine Plt. that they are active?
I'll let you know the what's and why's Tuesday.
Suavy
