What is needed for hoosier qtp's?
Old May 27, 2004 | 11:39 AM
samiam513's Avatar
what will i need to safely run hoosier qtp's on my truck?
58 in traction bars, driveshaft loop, and what else?
Old May 27, 2004 | 12:58 PM
yysenhimer's Avatar
Wheels
Old May 27, 2004 | 02:36 PM
whip's Avatar
I made a few passes on QTP's with out traction bars....but you are far better off WITH traction bars. If you can't wait to run them until you get your bars, just make some spring clamps to clamp the top two springs forward of the axle. (two peices of flat stock with bolts through them). Good luck, and hang on....cause she's gonna stick!!!!
Old May 27, 2004 | 03:47 PM
samiam513's Avatar
anything else?
Old May 27, 2004 | 10:29 PM
whip's Avatar
Nothin' man! Go buy them, buy some wheels to fit, buy some lugnuts for the type of wheel your using, install your drive shaft loop, some traction bars or spring locks, and go to the track and cut some killer 60' times!
