OBDII Code Questions?
I have since fixed my truck after the polished blower install and found that the #4 coil pack was never plugged in all the way. I went to Autozone and had the truck scanned and got a P0354 code thrown by the computer. The description for this code is kinda loose and just tells you coil pack D has a circuit fault. It took some research to discover coil pack D is #4 on the passenger side in the far back. Now what I would like to know for future reference is what the other codes for the driver's side coil packs are? Am I right in assuming that A, B and C are all on the passenger side? Thanks for any help you can provide
P0351 Ignition Coil A Primary circuit fault. P0352 Ignition Coil B Primary circuit fault. P0353 Ignition Coil C Primary circuit fault. P0354 Ignition Coil D Primary circuit fault. (#4 Passenger Side) P0355 Ignition Coil Primary circuit malfunction. P0356 Ignition Coil Primary circuit malfunction. P0357 Ignition Coil Primary circuit malfunction. P0358 Ignition Coil Primary circuit malfunction. |
Hello,
I just received a P0355 code, and I am not sure what to do??? Any suggestions???? Thanks, PS.. I moved from the Tampa Bay area to Ohio about a year ago...hows the weather down there now???? |
