F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   question for you Engine pro's (https://www.f150online.com/forums/lightning/155050-question-you-engine-pros.html)
MicLightning Apr 26, 2004 07:27 PM
found a guy selling a 2001 L with 38k miles..... said there is a problem with the #2 cylinder.... how much $$ am i looking at for repairs or what could it possiby be that is wrong? any input would be appreciated. Thanks guys.
-Sean
cpeapea Apr 26, 2004 08:30 PM
there could be anything wrong with that cylinder, what did he say? low compression? could be bent valve, worn or broken rings, spark plug threads. the money is a big variable, chances are itll be a good amount i would think
Thor01 Apr 26, 2004 09:21 PM
First, find out what diagnostics were done and where, that determined #2 has a problem. Go to that dealer or shop. Talk to the mechanic/tech if possible that worked on the truck. That way you get the whole story.
See if he is willing to do the repair on the side or shop around for estimates. Also ask the owner why he isn't having it fixed prior to selling.
My $$$ is that he had mods, plug fried and lost the electrode and it took out a valve or it launched a plug. The only true way to determin the amount of damage without pulling the head is to look into the cylinder with a boroscope.
If your going to replace one head, might as well do both along with the new new headgaskets. That's only if you get the truck for a deal seing it's hurt. If you don't get this truck. My advice is if your looking for a used pre dated 03 Lightning. Find one with 03 heads or look at pre owned 03 Lightnings.
That way your not keeping your fingers crossed on launching a plug every time you get in your L for a drive like the the rest of us pre 03 MY L owners.
MicLightning Apr 26, 2004 11:00 PM
he said it runs, but it misses at certain speeds.... gears im guessing is what he means. Anyone know what that might be?
cpeapea Apr 27, 2004 07:01 AM
maybe the coil pack went bad or, like thor said, the electrode has been fried off the plug and it misses or breaks up at the higher rpm. pull the plugs and check them all
Mondo1 Apr 27, 2004 07:19 AM
I'll betcha its a plug.;)
MicLightning Apr 27, 2004 12:27 PM
so if it is a plug or coil it should be relatively cheap to fix correct?
halflife Apr 27, 2004 01:02 PM
Do a compression test. I am having trouble with cylinder 8. did a compression test and it only has 5 psi. I had similar issue, changed plugs and coil pacs with no luck. then did the compression test.
