Underhood squeek
Old Dec 16, 2003 | 12:24 PM
vpat's Avatar
Underhood squeek
Has anyone else had this problem? When the key is first turned to the on position, a chirp or high pressure squeek can be heard that sounds like it is coming from the air filter. It also happens at low speed when I get out of the throttle. I have and airaid setup and a Razors Edge smooth intake tube. Any advice?
Old Dec 16, 2003 | 12:43 PM
Grimace's Avatar
Fuel pressure noise in the injector rails? Mine does that sometimes, but it is a very high pitched, soft whine that happens after a wot run.
Old Dec 16, 2003 | 03:42 PM
MaxPower's Avatar
Try jiggling (technical term) the Airraid box, and see if it has any squeak to it.
My JL Ram Air setup squeaked for a bit then fixed it... actually my dealer fixed it
