power pipe question????
Old Oct 14, 2003 | 11:24 AM
  #31
Konig's Avatar
Originally posted by promodlightning
The filter came with my new JDM Pro-M mass air. It has studs imbedded into the filter and its 9 inches long by 6 inches in diameter...
so the filters are for the pro-m mafs only? wha do you mean by "studs"...I dont want to give up my maf, now that its polished and looks good.
Old Oct 14, 2003 | 12:03 PM
  #32
MISTERgadget's Avatar
The pro-m MAF's have a special filters and mounting setups, in which the filter itself is bolted ot the mass air (like headers on an engine head)
Old Oct 15, 2003 | 01:40 AM
  #33
promodlightning's Avatar
You can get those filters in pretty much any size and style. Ill find a good website for you tomorrow..
Old Oct 15, 2003 | 01:51 AM
  #34
Originally posted by TimBurntire
There is no way that a 1/4" thick metal tube will run as cool as a composite material. It will become heat soaked by under the hood temps and increase intake air temps no matter how it is insulated from the engine, whereas the composite material will absorb very little of the surrounding heat.
The heating effect of the aluminum is negligible. You can put your hand on it after a 30 mile drive and not get burned. Remember that aluminum is also used as an insulator and reflects heat. The cool down is faster else they would make cylinder heads out of composite. Either piece , REMs or C&Ls, serves its purpose. I had to accomadate a larger mass air and the C&L accomodated that while allowing me to use my PSP fast air kit....
