engine help dont know what to go with
I blew my moter i think and donk know where to buy and what i should get
>pistons >rods >crane cams >ported heads or any yall can think Justin |
It all depends on your budget what you should do. Did you throw a rod out the side of the block, if so thats junk.
I would call one of the tuners and buy a built short block. I would laso send them the heads off the stock engine, maybee they can be saved. If so they can install the heads on the built short, allong with the timing chains. that would make your work a lot easier. |
any of the tuners can whip you up a kickass block. i prefer psp.
no i dident throw a rod it is just makning a really loud onlr realy on letting off the gas and a little on cold start up so if you know a soulution then please help
thanks, Justin |
Originally posted by 01FordLightning really loud onlr realy on letting off the gas and a little on cold start up You mean like piston slap? Sound like a diesel? If you have a good dealer, see what you can do to fight to get it fixed, unless you've just got the 10k in cash laying around for a good built long block.... Then go for the whole works!! |
