F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   another guessing game on 1/8 mile et's (https://www.f150online.com/forums/lightning/126066-another-guessing-game-1-8-mile-ets.html)
ST.ELMO'SFIRE Aug 20, 2003 08:13 PM
00 "L"
dialblo chip tued by JLP and datalogged 11.4 afr
JLP air box
5lb lower
single blade TB
90mm mas air
factory tech valve body
2400 stall converter
no hitch or spair tire 3.55 gears
what times should i run with and without slicks say hosiers 28x 10.50's and stock f1's
guestimate 85 degree weather mild humidity
thanks guys just courious of how much diffrence slicks would make, btw i have ran a best of 8.7 before the 90mm mass air and the datalogging, and i had a hard time hooking in frst 60' were 2.1 avg.
any help is appreciated thanks.
chiketkd Aug 20, 2003 09:10 PM
Hey Aaron (aka ST.ELMO'SFIRE), it'll be interesting to see what times your truck puts down this weekend compared to mine which is 'bone' stock.
During my only trip to the strip, my best 1/8 mile time was:
60' 2.239
330 6.032
1/8 9.101
mph 80.60
I was running on the F1's with about 24psi in the rears. When we get back from the strip Sunday night, it'll be interesting to compare our times side-by-side.
I'll swing by Saturday, and we'll go racing Sunday!!!
ST.ELMO'SFIRE Aug 20, 2003 09:12 PM
Ok, cool:thumbsup:
chiketkd Aug 20, 2003 09:18 PM
Oh, btw my guess is that with 'traction' you'll be in the 8.3-8.5 range in the 1/8 mile with a trap speed in the high 80's.
C BROWN Aug 20, 2003 10:18 PM
Low 8's with the converter and slicks so long as the track is prep. half way decent:thumbsup:
lightning5.4 Sep 19, 2003 07:17 PM
E/T's
Here is what mine did
0light1 Sep 19, 2003 08:32 PM
I ran 8.8's the first time out just mashing it when I saw green. Then I made some homemade spring clamps for the rear springs. The next time out I feathered the launch and ran 8.4's several times with 1.9 60's.
This last time out the weather was perfect 66deg and I had installed some lakewoods and ran a 8.26 @84.54 with a 1.8 60' on stock F1's.
Learning how to Launch the L is key:
What I do (on stock F1's):
Tire pressure set at 25psi
I launch from a dead idle (foot OFF the gas)
I give it 1\2 to 3\4 throttle until I hook then I punch it to
the floor.
If you can hook-up 8.3 - 8.5 if not 8.8's
good luck
0light1
-2# upper
-4# lower
-Densos
-160deg stat
-custom air
-diablo chip
-lakewoods
-spring clamps (clamped 3 springs together)
