Pro's and Con's
Old Jun 19, 2003 | 12:10 PM
secstang03's Avatar
Pro's and Con's
Can someone please explain to me the good vs. bad of changing my mid-pipe to either one with 2 high flow cats or one with no cats. Will I need O2 simulators with both? I know that a pipe with no cats at all is not legal but could still possibly pass emissions here in Houston and if it didnt I would have to switch it out when its inspection time. Any info would help.
Thanks in advance
Old Jun 19, 2003 | 12:12 PM
cyntaxx's Avatar
If you get hiflow cats you will need 2. You will not need MIL eliminators though. If you plan on running a catless midpipe, you'll have to run the MIL elims to avoid getting a code.
Old Jun 19, 2003 | 12:13 PM
secstang03's Avatar
so if I you can get away with running no cats (cheaper) then why wouldnt everyone
Old Jun 19, 2003 | 12:16 PM
LIGHTNINROD's Avatar
TOO LOUD Ask Johnny Lightning..............
Dan
Old Jun 19, 2003 | 01:38 PM
cyntaxx's Avatar
VERY LOUD and emissions (although I am not certain if hi-flow cats pass these tests).
Also, some have said that you will lose low end torque by reducing the backpressure that much. I believe Hi-Flows from Magnaflow reduce it to 3psi, don't know what catless pipes reduce it to...
Old Jun 19, 2003 | 02:04 PM
Coldie's Avatar
save the environment
You don't get hardly any power by not running cats. You will lose low-end torque.
Not that I a tree hugging hippy, but hi-flow cats work. And they are significantly nicer on the environment and people around your car...
If it's a race only truck, go to town...
Old Jun 20, 2003 | 12:21 AM
Nazgul's Avatar
Re: save the environment
Yeah!
