Anyone in the 11's
On the STOCK convertor??? All summer i will be working my ass off for some major mods. And this fall when the air gets better again and humdity drops and dew gos away i am going to PRAY for a PERFECT air day and track day, put the ol Lightning on a diet and see if i can rip off a 11 second pass. So i was just wondering if anyone is running 11 on stock convetor, i guess if i cant do it then i get a stall but for now would like to try.
With all the mods for the Ls now. 11s on a stock converter is very attainable.
VINNIE |
I ran a 12.2 with stock convertor and 5# lower. If I had the balls to throw a small shot of juice, or more boost and less weight on my truck I don't see any reason why I couldn't have gotten an 11.
--Joe |
Stock converter here...
-Dale |
It shouldn't be to hard. I am hoping for 11's in a few weeks with the stock converter, stock 3.55's, and with 20's. I have ran a best of 12.35 a couple weeks ago on street tires and will have a NX kit soon. That should do the trick. I am running a 10# lower right now and put a 50 shot on that.
I did a 1.591 60ft 11.721 @ 114.56 on a stock converter with a temp of 85+ degrees. You can do it.
JE |
Originally posted by jagged edge I did a 1.591 60ft 11.721 @ 114.56 on a stock converter with a temp of 85+ degrees. You can do it. JE Actually it's funny you have a stock convertor..........I think it is the only stock part in your entire driveline :rocker: --Joe |
Originally posted by soap You don't count :devil: Actually it's funny you have a stock convertor..........I think it is the only stock part in your entire driveline :rocker: --Joe The new Kenne Bell goes in Monday. JE |
Originally posted by jagged edge Well it's not stock anymore... I now have a FT Monster Box and PI tq converter. The new Kenne Bell goes in Monday. JE --Joe |
My 11.7 was done with a stock converter a 2 lb lower pulley with the stock upper on 26" E.T. streets with the 22's on the front.
Bill Oh, I almost forgot, that was with a hundred shot.. :devil: lol http://www.baseballunlimited.com/lig...IUM-11.737.mpg |
:wave:
Stock convertor Stock blower All throttle/NO bottle |
Originally posted by hdmlnium My 11.7 was done with a stock converter a 2 lb lower pulley with the stock upper on 26" E.T. streets with the 22's on the front. Bill Oh, I almost forgot, that was with a hundred shot.. :devil: lol http://www.baseballunlimited.com/lig...IUM-11.737.mpg We here in Florida need a little more help in the 85-90+ degree humid temps. JE |
I'm 6/100th's of a second away from an 11
DO I COUNT ??? I have two 12.0 runs with Filter-Chip-T/B-n-4lb pulley No Exhuast No Tranny Work No Suspension Work No Electric Fans No Cobra Water Pump No Heat Exchanger No Thermostat YOU GET THE PICTURE Oh ya, 65HP of Juice Though :banana: :banana: :banana: |
Originally posted by Rob_02Lightning I'm 6/100th's of a second away from an 11 DO I COUNT ??? I have two 12.0 runs with Filter-Chip-T/B-n-4lb pulley No Exhuast No Tranny Work No Suspension Work No Electric Fans No Cobra Water Pump No Heat Exchanger No Thermostat YOU GET THE PICTURE Oh ya, 65HP of Juice Though :banana: :banana: --Joe |
Originally posted by Rob_02Lightning [B]I'm 6/100th's of a second away from an 11 DO I COUNT ??? |
| All times are GMT -4. The time now is 03:37 PM. |
