War about to start with dealer regarding Fog Lights
Heres the Scoop,
Last year I was billed for 3 sets of Fog Lights on my Lightning through Freedom Ford, Advantage Ford and Healy Ford said there was a service bulliton on them and it was a warrenty issue. I need the service bulliton or the warrenty number because my 03 needs lightd already and I don' t want to pay for them but, the dealer can' t find the bulliton number. I have seen it on here before can someone please provide me with it as I don' t really want to pay for it. Pat/Bluelightning |
Whassup Pat, how you been man :beers:
Sorry don't see it, but here's what they're listing so far for a 03 Bulletins for 2003 Ford Truck F 150 2WD Lightning V8-330 5.4L SOHC SC VIN 3 SFI Service Bulletins TSB Number Issue Date TSB Title 02-23-7 NOV 02 Cooling System - Premium Gold Coolant Service Info 02-21-1 OCT 02 A/T - Torque Converter Access Plug Dislodges 02-21-4 OCT 02 Body - Roof Ditch Material Cracking 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling hard to read it Go here for it http://www.alldata.com/TSB/20/032068DI.html Don't see it listed for 02 either ??? Bulletins for 2002 Ford Truck F 150 2WD Lightning V8-330 5.4L SOHC SC VIN 3 SFI Service Bulletins TSB Number Issue Date TSB Title 02-21-1 OCT 02 A/T - Torque Converter Access Plug Dislodges 02-21-11 OCT 02 Body - Cab Oscillation/Bounce at Highway Speeds 02-21-4 OCT 02 Body - Roof Ditch Material Cracking 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers 02-12-1 JUN 02 A/C - White Flakes Coming From Vents 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-5-6 MAR 02 Sheet Metal (Primed) - Preparation Procedure 02-3-5 FEB 02 Tailgate - Squeaking/Binding Condition 02-4-5 FEB 02 Battery - Charging Tips and Guidelines 02-4-1 FEB 02 Idler Arm - Replacement Specifications 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-21-5 OCT 01 Engine - High Idle/Sticking Throttle 01-20-5 OCT 01 Driveability - Vacuum Leak Detection 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure |
It's been awhile, but back when everyone was listing these bulitin numbers, there wasn't one ever mentioned for the fog lights. I took it to be that some were lucky. Some dealers charge SVT Cert fee while others warranty fog lights. Just the luck of the draw.
There was never a bulletin for the fog lamps that I was aware off.
My dealer replaced 3 sets of foglamps on my 01 under warranty. I guess it just depends on how you approach the service manger.;) |
I'm on my 3rd set too. good luck
What is all that stuff wrong with the 02. I have an trueblue 02
and none of that stuff wrong with it. At least that I know of how do I find out it runs perfect never seen a better running truck I do drive her easy tho with an occ. kick in the ass! mostly its just smiles for miles hey thanks for listening to me ramble on krueger :banana: |
Ive seen where some guys who had trouble getting foglamps covered, got assistance after calling SVT themselves..its worth a shot.
