F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   What's wrong with this picture... (https://www.f150online.com/forums/lightning/116412-whats-wrong-picture.html)
Lightningbug May 13, 2003 10:48 PM
Okay, I am a little frustrated with the performance of my truck. To date, the best I have managed, on Nitto Drag Radials, is below. This was about 4 weeks ago at Beech Bend in KY. Temp was81 degrees with barometric pressure around 30.55 and 100% humidity. Here are the numbers:
60ft 1.993
1/8th 8.38@85
1/4 13.03@106mph
Granted the 60ft sucks, but I feel it should have ran better than this. Here are my current mods:
2000L (CUX2)
K&N 12" cone filter (no airbox)
90mm maf
Breather cap
Accufab TB
Electric fan
4.10 gears
FT Valve Body
Cal-Tracs
Boost-bypass
Borla cat-back
Kenne Bell blower@12lbs boost
Diablo Delta chip on track setting (20 degrees timing)
108 octane fuel
Anybody agree this seems a bit slow for the mods?
ShadowLightning May 13, 2003 10:54 PM
woah....with the Kenne Bell Blower that seems incredibly too low. I see your times in the low 12's or so....chip timing? Check your burn on the chip!
whtlight01 May 13, 2003 11:07 PM
That does seem low but 100% humidity is a killer. maybe ty running it at night if possible.
Douconsulting May 13, 2003 11:13 PM
Even still, he's got 20 degrees of friggin' timing, with 12lbs on the Kenne Bell... You should have left the 13's long ago.
Also, if you think about it, your 60' isn't THAT bad... Especially for only having Nittos.
Have you had your truck dyno'd? I've run better times than that at 80+ degrees, in 90% humidity... All I have is a 6lb lower, on 15 degrees timing.
Red BOLT99 May 13, 2003 11:17 PM
It doesn't matter what Blower he has!
Its what amout of boost and tune and for what gas for witch timing!
I was running 13lbs and turning 12.7's but the weather wasn't 80 degrees either.
So there are alot of factors you just gotta get them worked out.
Get it tuned is the KEY! good luck:wave:
Lightningbug May 13, 2003 11:18 PM
Yeah, that's my point. I did put it on a Mustang Dyno a week before I went to the track and it made:
HP: 418.3 @4500 rpm
TQ: 510.5 @4000 rpm
:confused:
Don's Bolt May 13, 2003 11:43 PM
Re: What's wrong with this picture...
108 octane fuel
I have a question or two
20 degrees of timing seems way high to me. I feel you would be much safer running around 16 or less degrees of timing.
The 108 octane fuel is it leaded?? Most unleaded racing fuels are 104 octane, if you are running leaded fuel you prob have clogged you cats up. I have a feeling that may be your problem.
I will be back in NJ for some more testing on my KB next week. We learned a lot last time I was there and we only ran 12 degrees of timing. These blowers require a different tune than the stock Eaton blower. We have only got 4 runs total on the KB and one of them we tried something that didn't work, and one we lost traction so bad that we shut those two runs down early.
Next week I will be able to give you a better idea of what you need as far as tunning goes, but I don't think 20 degrees of timing is the way to go.
Lightningbug May 14, 2003 12:05 AM
The street setting on the Diablo is set at 15 degrees timing. The times on that tune were even slower.:(
As for the gas, I had 8 gallons of 93 octane unleaded mixed with 2 gallons of 114 leaded race fuel. It has given no sign of having clogged cats.
I agree that tuning is probably the answer. The problem is, I am 10-12 hours from any of the major tuners. I guess I'm just going to have to bite the bullet and make a trip up to the northeast (unless someone it willing to tune it at NMRA at Bowling Green this year;) )
Flying Mofo May 14, 2003 03:25 AM
You got wayyyy to much timing.
Also, check your head gaskets.
Coldie May 14, 2003 03:56 AM
Horrible dyno
Those are really bad dyno numbers.
With the eaton and a 2lb pulley I was pulling 430hp and 480torque on a mustang dyno (17 degrees of timing)
I would expect you to be close to 500 hp with your mods.
Coldie
Douconsulting May 14, 2003 04:41 AM
Running any amount of leaded fuel will kill your cats fast. Those dyno numbers are pretty low, for your mods... And, as far as tuning, you don't necessarily need to have it dyno tuned, just talk to one of the major tuners who has some experience with the KB. They'll get you on the right track.
Good luck!
Fast Gator May 14, 2003 08:07 AM
Just make a couple dyno pulls locally and then send the sheets with your chip to your tuner.
Your mph sure seems way off for your mods:(
'99 White Lite May 14, 2003 09:53 AM
Lead doesn't clog that cats. It just poisons the catalyst ruining its effectiveness as well as the catalyst in the O2 sensor ruining it as well. During open loop operation at WOT, you shouldn't notice a difference.
Lightningbug May 14, 2003 01:29 PM
It is one of the major tuners with experience with the KB that burned my chip.;) Another tuner won't burn a chip mailorder for my truck with the KB. I'd have to take it to their shop.
FastAsL May 15, 2003 11:47 AM
doesnt 100% humidity mean that it is raining?
wouldnt the track be closed if it was raining?
...chris
