F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   chip reburn with 410's (https://www.f150online.com/forums/lightning/112750-chip-reburn-410s.html)
wkuper11 Apr 8, 2003 10:59 AM
I know you need to have the chip reburned to fix the speedo with a gear swap but does the reburn do anything else? Can I drive the truck for a couple of weeks with the 410's without having the chip reburned? Or does the chip have to compensate for anything else? thanks
wkuper11 Apr 8, 2003 03:36 PM
ttt
HANKFAN Apr 8, 2003 04:41 PM
Yes you can drive it with the 4.10's and your current chip. Your speedo will be off as well as your truck will shift 300-400 rpm's sooner than it should though until you get your chip reburned for the 4.10's!
wkuper11 Apr 8, 2003 04:44 PM
thanks, thats all I wanted to know. :thumbsup:
HANKFAN Apr 8, 2003 04:49 PM
Are you planning on getting the 4.10's installed soon?
wkuper11 Apr 8, 2003 05:02 PM
I get paid on Fri, I am going to order them then, probably from LFP, and then Ill see If I can get my brother to install them, he works at a dealership but they are nazis about bringing in "outside" vehicles. If he can't do it I'll shop around for a good install price, I installed my own gears on my mustang but I don't want to mess around on a new truck. It was a toss up between JDM heat exchanger and the gears, I figured I'd do the gears first then get the heat exchanger in a couple of weeks and use up my last free reburn then. I am going to get the truck dyno'd on the 19th, hopefully Ill get high 300's on hp and high 400's on tq. can't wait.
