Kenne bell'd to better times!
Was at the track yesterday and got 3 out of 5 12.06 @115mph and 1.8 60 ft.
And wanted to say thanks to TEAM SWANSON. Danny was there all day for some final tunning that wasn't needed. What the hell do I need to do so I can get kicked out of a track around here!:p |
Good Job! Congradulations!:beers:
:drool: :bows: :rocker:
NIce runs!!!!! |
Aww...so the KB is not an 11 sec bolt on? I'm guessin it could be since you were so close. Congrats on the nice times though:thumbsup:
I think with a Single blade and 2400 stall. Thats all I'll need to be in the 11's traction was a bit of a problem tires were breaking loose in 1-2 shift. I was hot lapping it also?:rocker:
agreed
You are right Red, a convertor and t/b should get you there. Good luck on the quest!!!!:thumbsup:
Congrats Red Bolt
Thats Flying :thumbsup: :thumbsup: |
Re: Kenne bell'd to better times!
Originally posted by Red BOLT99 What the hell do I need to do so I can get kicked out of a track around here!:p |
Good job, Frank. You're right there. Get a converter and you'll join the club.:rocker:
115mph is plenty for an 11 second run. Get some traction and you're there!:beers:
Originally posted by Hamrhead 115mph is plenty for an 11 second run. Get some traction and you're there!:beers: |
Your 60 ft. is killing you.
You already have an 11 second truck without spending a penny more. Just keep working on launch and tire pressures. 115 MPH is fast. VINNIE |
:thumbsup: :thumbsup: WTG Red BOLT99
:bandito: |
I was running 17 lbs
and hoosiers were set at 15 lbs and thanks fallas I'll keep trying on my launch:wave: |
The track was so bad that guys were going 147 mph and 10.30s. Skip
| All times are GMT -4. The time now is 09:50 AM. |
