will this run 12's...?
2001 Lightning
12inch air filter... valvebody and 4x4 pan bassani exhaust 26x10.50x16 ET STREETS 170 stat 6# interchangeable chip set with stock shifts and something like 20 degrees(track) JL track bars... no e-fan no water pump no throttle body just wanting to get opinions...thats all. Thanks everyone. |
If the situation is right (cool weather,good driver,good track) he can hit the 12's.
Good god yes.........20* timing is pretty aggressive and your running a 6# lower.........hell in good weather you should run 12.5's.
--Joe |
My bad, I didn't see the pulley listed in his mods, now im thinking low 12's.:thumbsup:
I would say hell yes too.
Whats the altitude where you race?? I ran a 12.45 with a 2# lower, 1.5# upper, electric fan. no cobra water pump, line mod valve, and traction bars on my F1's. So as long as you get good weather and your not at a high altitude, I say yes. |
With 6lbs of Boost and that Timing, it better run 12's
I ran 12.8 with Filter-Chip-n-4lb Pulley on F-1's NO OTHER MODS (17 degree's of Timing, PIG RICH) |
do you guys think 20 degrees is a little too risky?
with 104 octance race gas 20 degrees is fine...on ****ty 91 cali gas hell no!
Im running about the same set up, 6# pulley, Diablo shift kit, 160 degree thermo, K&N open filter, Plugs, and Diablo chip with 19 degrees in it but I run 100 total octane in order to run with my set up. I run my L down til the fuel light comes on and that leaves me about 4 gallons of 93 octane and I mix my fuel from there to make sure my total gets to 100. My 1/4 mile time are in the 12.3's. So yes you can do it.
| All times are GMT -4. The time now is 10:57 PM. |
