What do y'all think about these numbers?
Last week I posted bad pics of dyno graphs. Here are the actual numbers. What do you think about the numbers and A/F? These numbers are with an addition of a 1# upper pulley (With the 4# lower).
https://www.f150online.com/galleries...2641-48175.jpg |
Oh yeah baby!!! Those ROCK!! :rocker:
OOPS. THe A/F numbers only printed on the corrected graph.
https://www.f150online.com/galleries...2641-48176.jpg |
Are the ET's in your sig run with these same mods?
Looking good. I wish I could generate that sort of horsepower at this altitude:( |
Originally posted by SCOTTSBEATER Are the ET's in your sig run with these same mods? Looking good. I wish I could generate that sort of horsepower at this altitude:( We are pretty much at sea level here and it was a cold day. |
I haven't had mine on the dyno yet and would be ashamed to post the results if I did. 5,000 ft can have a humbling effect on your #'s:(
Looks like if you were to bolt on some slicks you might dip into the 11's if the conditions were right. If not, atleast the 12.00's:D |
Originally posted by SCOTTSBEATER Looks like if you were to bolt on some slicks you might dip into the 11's if the conditions were right. If not, atleast the 12.00's:D |
Sweet!
I noticed those are 'Standard Correction' numbers. Did they provide you with 'SAE Corrected' numbers? The SAE numbers are what allow all of us to compare numbers across the country. The Standard's don't allow for the differences in weather, location, etc.
Never-the-less, those are great numbers! Dan |
I didn't get the SAE numbers. The Standard correction does correct for altitude and temperature, it just uses a different basis than the SAE does.
Correcting to SAE J1349 alters the data to make it seem as if it was taken when the atmospheric pressure was 29.23 in/hg., the temperature 77°F and the humidity zero. "Standard corrected," uses 29.92 in/hg and 68°F'. This is all according to Dynojet's website. As long as the same correction factor is used in another part of the country (SAE or Standard), you should be able to compare "like" numbers. Thanks. I'm happy with them. |
yysenhimer - what kind of A/F meter did they use?
Originally posted by captainoblivious yysenhimer - what kind of A/F meter did they use? |
wow those are some great #s!:rocker: looks like a strong runner!
| All times are GMT -4. The time now is 06:19 PM. |
