Torque specs on blower please????
If anybody can give me the torque specs on the blower and intake plenum it would be apreciated.thankyou.my porting and polishing is almost complete.Look out!!
I tightened the Eaton all the way down and then about a 1/4 turn. The Eaton is pretty forgiving. With the close tolerances of the aftermarket blowers...Kenne Bell, BDM, Whipple, etc. you will want to follow the manufacturers torque specs.
chimshady1,
Here ya go. If you left the rear 4 tight when you removed the s/c loosen them before you start sequencing.
1.) Pre-Torque fastners #1 thru #12 (2Nm) in sequence.
2.) Final Torque fastners #1 thru #12 (40-50 Nm) in sequence.
Rear
11------O______O----12
9----O___________O----10
5----O____________O----6
1----O____________O----2
3----O____________O----4
7----O____________O----8
Front
Rear
Front
