S/C Welding Mod
S/C Welding Mod
Stock
Plugs were made to fit holes exactly.
Some grinding is still left to do for rotor clearance.
The holes on the bottom were made bigger
then filled for a stronger weld.
I assume your welder heated the casting prior to welding. That way, the welding heat won't warp the housing as much.
Make sure you check the rotor clearance all the away around on assembly. Welding aluminum without warpage is tricky.
I still think this is a better method than JB weld.
