F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Interior Care (https://www.f150online.com/forums/interior-care-49/)
-   -   Ash Tray won't stay closed (https://www.f150online.com/forums/interior-care/359392-ash-tray-wont-stay-closed.html)
Bair284 Jan 10, 2009 02:59 PM
Does anyone know how to remove or fix an ash tray on a 04 FX4 with captain seats. I know this was already discussed previously however I have a different set up since I have captain seats and is not the same as a reg. cab
jessiebouc Jan 10, 2009 05:31 PM
I had the same problem with mine. I ended up ordering a new ash tray from Ford and replaced it. You open the ash tray and pull on the radio bezel trim to remove the trim. The trim pulls off towards you. Then you will see the 2 screws that holds the ash tray in place.Once you remove the ash tray, you can tell whats wrong with it. If you can't open your ash tray, I would carefully pry it open. Hope this helps.
Bair284 Jan 11, 2009 07:49 AM
thx
yetti96 Jan 11, 2009 11:14 AM
The pin that slides in it's track was barely meeting up and not working properly on mine. I don't plan on fixing mine as it will be my switch panel.
