Headliner and dash cleaner
for the headliner mist it lightly with water and wipe off with a towel, for the dash use a gentle cleaner mix it with water in a bucket and dip your cleanig rag in the solution and wipe off the plastic areas. follow the plastic up with a good quality protectant (water free)
'99 XLT S/C 4.6 Auto White, A.R.E. Hard tonneau, ventvisors and bug guard all painted to match, Kenwood 6 Disc, Westin nerfs, Buccaneers front license plate!
Try Lifter One Stain Remover. I bought it at Pep Boys. It is in a light blue can. I had some blood on my headliner from squashing skeeters while I was four-wheeling and I did not think anything would get the stains out, but this stuff really worked. I have the tan interior if that makes a difference. Hope this helps.
Here's an inexpensive way to go..."Simple Green" concentrate. A mix of 3parts h20 to 1 part simp. grn works great for the dash. You can strengthen it to clean the headliner if you need to. Also, the dashes/glovebox door are painted in areas so DO NOT SCRUB or you'll remove the paint...even using water! Then you'll have an ugly black spot where you wore through.
Ford makes a product called "Triple Clean". It may be expensive, but it is an all purpose cleaner (interior panels, carpet, upholstery, and even exterior). I suggest testing an inconspicious area first. I recommend it to everyone.
You will be amazed. It works really well. We used to use it if a lube tech got oil or grease everywhere.
'98 4.6 5-sp F-150
We've come for your Tundra.
http://www.mcmullenargus.com/gallery...ge=1165&pub=12
trixters-playground@excite.com
www.truckinweb.com
[This message has been edited by crash1 (edited 11-25-1999).]
'98 4.6 5-sp F-150
www.truckinweb.com
