Bent6 removing headlight switch
I installed the lights in the bumper,ordered the dealer install kit. It came with the new switch, and here is how to remove it.
You first pull the **** off then turn it 180 degrees and put it back on then turn it. It acts like a key to pull in the springload clips. Honest it works, was in the instructions for adding the offroad lights.
sorry , turn the switch on, pull it out as to turn on the fog lamps, opposite the pointer mark a small openning , stick in a paperclip, this will release the ****
the target is straight in and is small
the **** comes right off, then put it back on 180 degrees (it will not lock on) then turn the **** to release the switch
[This message has been edited by Bracketracer (edited 11-21-1999).] http://homepages.msn.com/YosemiteDr/...ay/switch.html
for pics of this proceedure
