Cruise control bulb on dash
For several years I used a red LED in my 3rd brake light. As we all know this kills CC. I finally replaced the bulb for a stock incandescent and my CC works again, but the light on the dash doesn't. (This solves another issue from another post as to whether CC will work with a burnt out indicator lamp....it does at least on my SCAB.) I have seen umpteen videos on how to remove the cluster and replace the bulbs but none address the CC bulb directly. Is this one of the PCB diode lights wired in and not a regular bulb? Is there a diagram of the PCB showing the bulb sockets and which is which?
Any help would be great. I can still use my CC but I want the light back.
I figure if I'm gonna remove the cluster I might as well upgrade to LED's for it.
Cop-in-the-mirror blue should do the trick.
