Led Tails No Cruise
Old 01-20-2016, 07:52 AM
cw974x4's Avatar
Led Tails No Cruise
I replaced my rear tail light Assembly with Led assembly's now I have no cruise I have checked everything all fuses anyone else run into this problem? I have had my third brake light switched to a led for about 7 months now with no issues I bought the led tails and now no cruise. any help appreciated.
Old 01-20-2016, 07:58 AM
nu-supercrew's Avatar
Did the LED assembly come with a resistor of some kind?
Old 01-20-2016, 11:20 AM
projectSHO89's Avatar
See this thread: https://www.f150online.com/forums/el...t-working.html
The replacement of all the incandescent lamps removed the "pull-down" function that was provided to the logic signal for the BOO (brake on/off) status. With only LEDs installed, the circuit floats to a logic "high" and the vehicle electronics think you have your foot on the brake pedal.
Old 01-21-2016, 07:49 AM
cw974x4's Avatar
Thanks Guys i will get a resistor and try installing it on my third brake light. I love this sight always quick and great responses.
Old 01-21-2016, 09:10 PM
I have Spyder LED tails which were wired and resistor installed already, also have an LED 3rd brake light. I have no cruise control or flasher issues. Definitely is the lack of resistors.
Old 03-04-2018, 11:43 AM
LC911TX's Avatar
No Cruise After LED Bulb Install
I have a 2006 F150 that I purchased new. I installed led bulbs and now my cruise control does not work. The problem is not in the led 3rd brake light, as the issue didn't show up until I put led's in the front turn signal/park and in the rear brake/tail light sockets. I have already changed the flasher module, so I do not have the hyper flash issue. My cruise control just stopped. What can anyone tell me about the load equalizers or resistors that I see people talking about?
Old 03-04-2018, 11:46 AM
Does your 3rd brake light work? Is it LED or incandescent? You have to have ONE incandescent bulb in there out of three that works (or a suitable work-around) or the speed control won't work.
Old 03-04-2018, 11:59 AM
LC911TX's Avatar
The led 3rd brake light works fine, and the cruise control worked with that. It did not stop working until I put LED bulbs all the way around the truck
Old 03-04-2018, 01:28 PM
Go back and READ what I just said. To make it easier, I'll go back and add emphasis to the pertinent sentence.
You broke it when you installed the last LED light.
Old 03-05-2018, 07:11 AM
LC911TX's Avatar
Ok, I see what you are saying. My 3rd brake light is all LED's. Once I changed the tails to LED, that stopped the cruise from working. Is it worth putting these resistors in, or just go back with OEM bulbs, or just not have cruise?
I guess that is the decision I need to make.
Thanks.
Old 03-05-2018, 07:17 AM
You decide, no one can do it for you.
Old 03-05-2018, 06:14 PM
I think I'd rather have cruise, but that's just me.
Old 03-12-2018, 11:03 PM
Bigun05's Avatar
i installed a third brake light and my cruise doesn’t work so I installed resistors and still the same. No cruise!
Quick Reply: Led Tails No Cruise
