Flush mount LED's into rear bumper...
Anyone have any tips?
I just ordered 2 flush mount square LED lights to use as back up lights... Says it needs a 3-1/8" hole. Guess I'll tape it off and use a dremel or something. Anything I can do to help prevent chrome from flaking and peeling in the future? Also, best way to get the wires into the CAB under the dash to tie into a switch? My old F150 had a hole on the firewall near the break master cylinder. I would assume my 2013 will have one too?? |
Originally Posted by 03Fx4JD
(Post 5132493)
I just ordered 2 flush mount square LED lights to use as back up lights... Says it needs a 3-1/8" hole. Guess I'll tape it off and use a dremel or something. Anything I can do to help prevent chrome from flaking and peeling in the future? Also, best way to get the wires into the CAB under the dash to tie into a switch? My old F150 had a hole on the firewall near the break master cylinder. I would assume my 2013 will have one too?? 2. Wire routing (encased in wire loom). Not through the firewall, but the door sills. As shown here: https://www.f150online.com/forums/ar...-how-pics.html |
Ok thanks I'll check it out.
I think, depending on what's behind it clearance wise, I might try to mount them in the plastic part each side of the tag. Between where it dips in, and where the chrome starts.
Well lights came in.... still waiting on the blasted switch though. Ordered a OEM part ;) that I'm going to use to cut my lights on/off with. I hope. haha...
(Post 5133670)
http://www.otrattw.net/CONTURA-V-FOR...ZC77-F150.html http://www.otrattw.net/images/P/77F150.jpg MGD |
eh.... I got something a little different in mind...... Just gotta wait for it to come in.
http://www.ebay.com/itm/331254645359?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
-OR- https://www.f150online.com/forums/il...ml#post5121408 MGD |
not bad.... but can't wait to show ya'll what I got in mind once it gets here.
Switch came today. Hopefully it will warm up enough to work on it this weekend.
