Halo for a Ford F-150 1998
Ok so I really want halos for my truck. But I want the square ones. I've searched oricle I've searched automotive light store but I can't find any tht will fit my truck because there all made for the newer models but I've seen them on a truck like mine. Any suggestions on where else I can find these please help
Ok - having established that, and the fact that y'all DID say 'please', perhaps what you saw was a DIY effort using flexible LED strips.
There are any number of sources for those - they come in either fixed or cut-to-length varieties. Try TRS, Autoillumination, Superbrightleds, Fleabay and Amazon, to name just a few.
Good Search - like Good Sex - requires a lot of practice.
BTW - you do realize that most of these install within the headlight housing, requiring you to bake them open, separate the lens, install, wire, and then reseal with butyl, right? If you were planning on just tacking these things on outside, I'd reconsider, as that would look spectacularly homosekky.
Good luck
MGD
