passenger front signal issue
ive run into an issue where my passenger front turn signal isn't working. it all started when I tired putting led switchbacks in with external load resistors. they weren't working so I put the regular bulbs back in. now the front passenger signal isn't working. checked fuses and they are all good, put a meter to the wiring at the bulb and was getting the same reading as the drivers side. switched out the bulb socket from side to side. passenger side works on drivers side but drivers side doesn't work on passenger side. im at a loss for what it could be. please help
thanks
thanks
Sent from my iPhone using IB AutoGroup
So you swapped bulbs and sockets between sides? Yet you say you get voltage to both sides? Something doesn't sound right. If you get voltage all the way through the socket and the bulb is good you should get light... Maybe I am misunderstanding your description or you have a Gremlin there...
