Any way to improve Factory HID?
Hey guys,
I just got a 2014 Platinum with the factory HID's. My previous F150 had a retro done by Black Flame customs, which was sweet. I had 3" FXR projectors, 5000K D2S bulbs and 55W ballasts. It had nice, clean cut-off lines as well. The beam width and output was amazing.
Going from that to my factory HID's in the new truck is like night and day. It's rather disappointing actually. The beam pattern on the factory setup isn't as wide, and it's definitely not as bright IMO.
Black Flame can do a "clear lens" upgrade which is suppose to help with light output as well as a sharper cut-off. It's a cheap mod, so I think I'm going do do it. However, I was wondering if anybody else has done anything to try and improve their stock HID.
Thanks guys.
Thanks guys.
Unless you are getting old and need the extra light to see.
Thanks guys, this is awesome. Is the EVO-XR a direct replacement? Meaning does it fit in the the same screw holes (or whatever) that the stock projectors came out of? I ask this because I am extremely picky when it comes to rotation on my retrofits. Duce, yours look great and perfectly level to me. Did you have to fiddle with rotating them and making sure they're level and even, or did the projector just bolt right in, and it was already level because it was just replacing the stock setup, in the exact same location, etc? (if that makes sense).
I've had 50W ballasts before, for most of my stuff and I'm pretty used to it for either city and/or highway driving, so that wouldn't be an issue. I haven't taken my lights apart yet, so I don't know what the factory plug looks like. But if you run a D2S bulb (or any other bulb besides the stock D3S), along with an aftermarket ballast, does it still plug and play into the factory harness, just as easy as any other retrofit would?
I had mine done by Dawson at raptorretrofit.com as I was WAYYY to afraid to pop open $1,200 headlights. But yes, the EvoX-R is the only direct bolt in projector for the OEM HIDs. You will need to convert over to D2S on bulbs and ballasts. And you will also need a new harness w/ relay for the conversion.
Side note on 55w. If you plan on running the best bulbs CBIs, night breakers, Phillips I suggest not running 55w ballasts until TRS fixes their current ballasts problems. They aren't operating perfectly and causing bulbs to die way before they should. Granted not all their aftermarket ballasts are doing this but there is a chance you can get one that flickers like crazy on heat up which is very detrimental to the bulbs.
Now if you are going to run their 3Five or XB bulbs that don't cost nearly as much to change then you should be fine.
If you plan on using OEM bulbs (listed earlier) I would suggest using the Matsu****a's or denso. Yes these will only be 35w but the reliability there is top notch.
But that's why I suggest the OEM ballasts at the end.
