One step away from true HID projection!
Well guys the time has come and all i've got left to do is align the projectors. It was actually pretty easy of a process compared to what I have heard people say.
I went with the FX-R Stage 3 kit. It can be had from theretrofitsource.com but I bought mine from a fellow member who bought it and didn't have time to install (Milt IV). He had bought E55-R Shrouds, but after test fitting them I have decided on and ordered Apollo shrouds (be here tomorrow or Monday) It took me around 2 hours to have the headlights apart (bought ebay brand for clear reflectors and ease of taking apart), hole dremelled out, and projectors screwed on. I then put the project on hold until I was able to paint the reflectors bucket and housing Oxford white and clear over it with PPG clear for a factory finish. The painting took the longest because I spent so long sanding every crevice, ect. But once it was cleared it was apparent it was worth the energy. Once I had everything dry (this morning) I started to put it all back together. I mounted my ballasts on the backs of the headlights (test fitted them to make sure on the truck) and epoxied the high/low solenoid wires where they went through the housing. I screwed the relays on the top of the washer res. for ease of access and clean look. Housings are now mounted to front lens and the reflectors got a dab of epoxy on the clips to ensure longevity. Heres a few pics to keep people up to date. The housing. I used the same clear I use on the tail lights and PTM emblems I sell on my website. They turned out FANTASTIC looking. OEM finish. http://i770.photobucket.com/albums/x...t/f440004d.jpg http://i770.photobucket.com/albums/x...t/b2503d42.jpg http://i770.photobucket.com/albums/x...t/feaa4932.jpg Pic of the painted bowl showing where I cut out with my air dremel. The back seal is out until final fitment. http://i770.photobucket.com/albums/x...t/0abe056a.jpg http://i770.photobucket.com/albums/x...t/6a803473.jpg http://i770.photobucket.com/albums/x...t/6e306041.jpg Showing where bulb comes through. No seal yet. http://i770.photobucket.com/albums/x...t/3531bc18.jpg Where Hi/Lo wires come through. Sealed up with epoxy around them now, not in pic. http://i770.photobucket.com/albums/x...t/dd2cec21.jpg For the ballasts I used double sided mounting tape and the supplied bracket. You can see the bend I put in the bracket to let it slide up enough to let the top bolt clear the housing. Also notice how I doubled up the tape in a certain way so that with the bracket on it still has enough depth to fully contact the housing for a strong hold. The mounting tape combined with the bolt should last forever IMO. Very sturdy feeling and more OEM looking than screwing it to the fender somewhere. http://i770.photobucket.com/albums/x...t/9e1b799e.jpg http://i770.photobucket.com/albums/x...t/0cc3d9a2.jpg Here they are mounted up. http://i770.photobucket.com/albums/x...t/7442e8be.jpg http://i770.photobucket.com/albums/x...t/91c7999b.jpg I will try to remember to take some pics tonight when aligning them. Until then, see ya! :roflol: |
If that ballast mounting spot works without modifying anything then you sir are a genius.
Hopefully you have the new wiring harness from TRS. I have the older version and I wanted to mount my ballasts like that but the harness wouldn't stretch far enough across to the driver's side headlight for it to work. I found a nice spot on the engine bay frame that works fine though.
Lights look good so far! |
I already test fitted. 3 inches of wire slack in the harness and 1" of clearance to the truck all the way around :thumbsup:
Lights look good, great job. Can't wait to see the rest.
Did you take the bowl off from the backing of the headlight? Or did you leave it on and tape off when you painted it? |
Originally Posted by Mrocha85
(Post 4860719)
A+ on the prep work. Do you anticipate some trimming will need to be done on the surrounds?
(Post 4860786)
I was considering this mod but using the MORIMOTO MINI H1 5.0. Do you guys think they will look to small in the headlight?
I would just stick with the fxr.. Better output from what I've heard. Here's some pics of the lights showing clearence of the ballast and the cutoff.
http://i770.photobucket.com/albums/x...t/2434c58b.jpg http://i770.photobucket.com/albums/x...t/e4b38c90.jpg http://i770.photobucket.com/albums/x...t/531ccc52.jpg http://i770.photobucket.com/albums/x...t/9a1d89c2.jpg http://i770.photobucket.com/albums/x...t/b54edefc.jpg Msall, why do you think my hi signal light is stayin on in the dash? Also my high/low switch is backwards.. Not sure what to do about that. Other than that I love them! Once I get the shrouds in they are getting sealed up! |
Those look great!!! I need to get my kit installed.
Also witch switchbacks are you running? |
Lookin good Brent!
V LEDs switchbacks here. Thanks guys!
Originally Posted by Lifted5.4Lariat
(Post 4860863)
Msall, why do you think my hi signal light is stayin on in the dash? Also my high/low switch is backwards.. Not sure what to do about that. Other than that I love them! Once I get the shrouds in they are getting sealed up! Lookin good! Much better job than I did |
Yeah bambi mod and check your pins for sure. Runnin PnP fog HIDs always illuminated that damn high beam thing. Since the projector have excellent foreground lighting you really don't need foglamps, just switch them back to halogen and see if that fixes it.
