Interior/Exterior LED lights installed PICS
Hi guys,
so ive been wanting to convert all of my hvac controls/speedo gauge clusters to blue so they will match the other blue i already have going on inside. I can figure out the gauge cluster but the hvac controls are giving me more trouble, even though ive heard that's the easy part.. i took the whole console completely apart down to the green switchboard and i cant find any bulbs? is is just a green overlay thats emitting that colored light or are the bulbs actually green? any help would be greatly appreciated, thanks in advance!
Yes the part #s and counts I listed are the exact same for you because you have the 2 lights up front and 3 lights in the rear. It is different for those with sunroofs and those with regular cabs. Yours require the exact same as mine. You need 1 pack, 2 bulbs, (194), from my first link and 3 packs, 3 bulbs, (211), from my second link. You will probably have to pinch the tabs that hold the lights in place together a little bit to get them to hold the 211s tightly. That is what we all had to do. I am basing all of this off the research I did in the 04-08 led interior thread. You can do more research if you don't trust mine. Here is the link, all 52 pages of it.
https://www.f150online.com/forums/20...-complete.html
Probably right after christmas. My awesome brother just sold the ones out from under me I was gonna buy from him so now I have to find the extra set to send to you.
I tried those lights for the cargo and go almost no light in the bed itself. Can you get a pic of how it lights yours up? I have a line-x which might make a difference.
Also have you replaced the puddle lights (if you have them?) I really want to do those sometime soon.
I'm not sure what you mean by "puddle lights".
hey Milt, i got an '07 FX2 no sunroof with the rail. I assume the front map lights (194) would be the same as the back map lights, but you went with 3 211 bulbs? So the dome bulb is the same as the map bulb in the back, but different than the ones in the front?
Puddle lights are lights on your mirror that light up the ground when you step out of your truck i believe...
BTW, anyone got a coupon code for V-LEDS right now? it will help me with the 20$ shipping charge since I'm over the border but only 2 hour drive away
Keep in mind this pertains to the 2009-2010 SCREW with no sunroof. I advise everyone to pop the covers off their lights and get a physical count on the bulbs and look at the type of bulbs they are. It takes all of 1 min to check the front and back. The light configurations vary between models, years, and even trim levels in some cases. Better safe than sorry. Physically looking combined with a lot of research, is how I ensured I bought the right stuff the first time.
I just did this to my 2010 Scab and was amazed at the difference. I originally used a 3chip 5 led 194 for the front map lights, but was did not have the light output that i was looking for so i swapped them out for a 2watt 4 led that are aimed straight down and got exactly what i was looking for with the 4 led 578 festoon bulb in the rear. I ended up putting the other 194's in the license plate spot since i had no other use for them and was also impressed with the light output over the incandescent.
For the rear dome lights i used these: http://www.v-leds.com/Interior-LED-B...-p9454129.html
The license plate i used these: http://www.v-leds.com/Exterior-LED-B...-p9722412.html
and finally the front map lights i used these: http://www.v-leds.com/Interior-LED-B...-p8761053.html
