1998 F150 no heat
1998 F150 no heat
Got the truck in October and heat has worked fine in the past. The other morning it was 27 degrees out and heat hasent worked since. I checked coolant and it was low so I topped it off. Radiator hoses hot, heater core hoses are cold, both of them. Truck does not run hot at all but I have always heard water running through the core before, and in my old GMC, and it no longer does that. When I turn it from hot to cold I can feel a difference so I don' believe it' the blend door. I' leaning towards a clogged core, bad water pump or thermostat or all of the above. BTW, 4.6 v8 295k miles. One thing that was weird the other night was after I topped off the coolant the temp gauge wouldnt read. As it was running I slowly cracked the overflow cap and got a lot of pressure and then the guage started working again. Any suggestions before I start throwing parts at it?
I thought about that. Oil is clean, no water. Doesn't use that much coolant but I have noticed a small puddle under the truck right about where the heater hoses connect to the core. Wondering if it' leak8ng from there because it isn' much.
