2002 A/C dash vents issue
Hi Forum, I have a problem I hope ya'll can shine some insight on. When I turn A/C to Max or A/C, I hear the fan running full blast in dash, but it is coming out defroster vent, then without touching anything, it will start blowing out vents, then back to defrost vents. It seems to be cycling between the 2. I thought maybe A/C was low, but it is blowing very cold, just keeps cycling between vents and defroster...any ideas what I need to check :help: ?? Thanks
Check the little hard vacuum lines behind the battery for cracks.
2 Attachment(s)
Originally Posted by glc
(Post 5110895)
Attachment 39249 Attachment 39250 |
Originally Posted by Mach 1
(Post 5111122)
I CAN use a rubber line right??
Cut it clean on both sides of the break and bridge them with a rubber vacuum hose.
(Post 5111167)
I replaced that piece with a vacuum line bridged between break..still doing it, any ideas what else to check??
You probably still have a vacuum leak in the system.
(Post 5112598)
The line goes into the fenderwell to the vacuum reservoir. It also goes through the firewall to the HVAC control unit.
A Mityvac pump is invaluable for troubleshooting problems like this. |
