1998 F150 5.4 A/C Problem
I have a problem that just started about a month ago. My A/C has always worked well, no leaks in the system, compressor is also good. When I first start the truck, the A/C blows cold. As soon as I hit the accelerator I hear a clunk in the vents then it blows immediately HOT. I was driving today on about a 3 hr trip and the A/c blows hot until I stop at a light then I switch on the Air and it works good. As soon as I hit the accelerator same thing, clunk the immediate HOT. Does anyone have and ideas about this? I think I may have a vacuum issue but I don't know alot about A/C systems.
Thanks I wasn't sure but, I will look around to see how to fix it. Thanks.
Well I pulled the floor vent out and the acuator. When I pulled the acuator out, out fell three plastic pieces. I fould the problem now I need to fix. Not sure if I am up to pulling dash out or not.
actuator
thanks
blend door
I wish mine was that easy, my dash has to come out, i have cut the hole and taken the door out but i can access my activator motor, thats why the dash has to come out, if i could bend the metal piece at the top up out of the way to get the door in i could and i may have to cut one side of the circle piece that hold the top of the door to bend it, i might could get it in but it back in there a piece and im not sure that im going to even fix it my son suggested putting 2 cutoff valves under the hood on the heater hoses and just turn them off in summer, one thing i do know is im not pulling the dash, and damn ford for making this mess
Why do you think it's the blend door? Are the high and low pressures correct? Is the compressor clutch engaging?
hey
i cut the hole behind the dash and took out the door that was broken at the bottom, the activator is working but i have no access to it under the dash,
