Arg.....wire harness's question....
I am I supposed to have two harness's? I just pulled out the stock single disk and there are two plug-in's in the back. A long rectangular one and a smaller rectangular one. I only have a harness for the larger rectangle one: http://www.crutchfield.com/p_1207055...s.html?tp=2977
Do I need another harness for the smaller plug-in? Thanks! |
The large rectangle one has all the power wires, ground, speakers, etc so that's all you need if that's all you are powering.
The extra one is there in case you have the factory sub and want to use an aftermarket deck to power it. If you don't, then you only need the one harness you already bought. |
It's just seams odd that the small one was plugged into the back of the factory deck and I don't have a factory sub.....
I used the large one only an installed my Alpine. Everything works good. Thanks |
Most trucks are already prewired for the sub. I think most guys have found it up by the seat brackets under the backs seat.
Anyone happen to have a pic of the wiring that goes to no where? I'm wondering now cause I found 3 sets of RCA's and a remote wire behind the factory deck (the truck was bought used) leading to behind the rear seats.
Originally Posted by Neurotoxin
(Post 3973136)
Thanks!
that smaller plug also has the wiring in it for a stock cd changer.....
im in the same boat because i just bought a brandmotion ipod connector and i cant find that small square plug and my ipod connector aint working so im gona try to see if thats the cause of it. My truck is a 2005 ford F-150 XL
Originally Posted by Fordtruckman88
(Post 4030588)
| All times are GMT -4. The time now is 03:36 AM. |
