dropped my harley
harleykid19
I'm pretty sure it will work, my kit is a 1/2 drop. I think I need one more inch in the rear.
ROADKINGSS
I got the X-pipe from a local muffler shop for $70.00. They had it in stock so I got it. You can order just an X pipe from spin tech I don't know the web sight or phone number but if I find it I'll let you know.
abullerm
if you go with a bag system you should go with a 4 link for the rear. I don't know what it will do to the performance you may have allot more body roll but I'm no expert, It just looks like allot of work installing all the lines air tank air compressor switches in the cap to control everything and C notching the frame too much work for me. But you would be on the ground.
https://www.f150online.com/galleries....cfm?gnum=1251
ROADKINGSS
abullerm
That 1/2 looks pretty good. Just what I'm looking for on my 01. If you put a bed lid on it might sit a little lower in the rear. My ARE is fairly heavy and I think helps set it down. You say you used a Ground Force kit right? Where did you get it.
I'm also going to put a rear sway on, Hellwig I guess.
lrutt
Yes it was a 1/2 ground force kit. I got it from a local shop called truck n america. You can go to ground force web sight http://www.groundforce.com/fordpag.html I hope this helps. By the way it took me longer to take the tire off and place the jack stand under the truck than it did to lower it.
Roger
Roger
The ground force kit # is N9902
1” front
2” rear
99-up
Lightning / F-150 Harley Davidson
1” front
2” rear
99-up
