finally got cover ordered
i finally convinced leer with the help of the previous owner of my truck to oreder the cover. so it is on order now and i will have my order # by thurs. who knows how long the cover will take though. but i assume it wont be too long because most of them are already installed.
-steve
-steve
It is worth the wait!! The key cylinder will not match your ignition key. If you want it to match you will have to take it to a locksmith.
It cost me $23.00. If you choose to do that DO NOT LET THE INSTALLER PUT THE KEY CYLINDER IN UNTIL YOU TAKE IT TO BE KEYED. When I received my top it did not match so I called Leer & complained and they sent me another key cylinder to be keyed & said the key actuator would brake when the old one is pulled out.
I tried to install on my own & now I am screwed. (The locksmith said to pull the clip & put the new one in) The installer has the new actuator, but they are unsure if they can feed the new assembly in the enclosed area. I am waiting to hear from them. In the mean time I had to unscrew the hooks so it would not stay locked-when the top is down you can not open the tailgate!!
