spring hangers?
spring hangers?
i have a 02HD w/2in shackles in rear installed all ready.
i would like to be lower someone said they make spring hangers
to lower it more,then i can put in the front springs.
can someone tell me where to find the spring hangers?
thanks in advance
tony
thanks in advance
tony
not sure if they sell just the hangers, but check out www.lightningforceperformance.com they have really good prices
rear hangers will get you 2 additional inches out back, for a total of 4". You may want to raise your shackles up to the 1" mark though so you have a 3" drop out back cuz you'll bottom out alot.
and if you drop the back, you'll need to drop the front for it to be level again. just remember with the HD's, a 3" drop coil for a regular F150 will only net a 2" drop on the HD's. and a 2" drop coil for a regular f150 will get a 1" drop on the HD up front
but if it says 2" drop coild for a Lightning, it'll still get the 2"
good luck
if you go with the 3/4 setup, you may want to get new shocks also
good luck
thanks for the info!!!!!!!
i have the motorsport lowering kit for a lightning,
but i only installed the shackles because i wanted
to level the truck.now i want it lower.
tony
tony
