Excel Spreadsheet help
I have absolutly no experience with Excel. But I have a spreadsheet that i need help with.
What I need to do is add a percentage to a column and create a new column with the figured price.
For example
Columm D + 20% + column H
I know this is possible what formula do I need. Don't forget I am really green at this.
Marvin
For example
Marvin
I'll give this a try
Okay try this. My example will use columns A, B, C, and D. You can use whatever columns you need.
A1 - enter your price (assume 45)
B1 - enter the percentage (20% or .20)
C1 - enter this: =A1*B1
(C1 should now read 9)
D1 - enter this: =C1+A1
(D1 should now read 54.
I hope this helps
I hope this helps
If cel a1 is the price and you want to show the result (price a1 +20 %) in cel b1 then insert this formula in cel b1.
=a1+(0.2xa1)
To insert formula's in all cells of column B.
Highlight cel b1, copy.
Select all cells that you want in column B.
Choose paste special......
Choose radio button formula's
OK
Hope this is what you mean.
This is for a fixed percentage of 20%
=a1+(0.2xa1)
OK
