Pc Help Please
Old Jan 30, 2011 | 02:23 PM
Agent47's Avatar
Pc Help Please
I have just been trying to fix my wife's acer laptop as its got some kind of problem that may be viral. She has been using the free version of AVG but wanted to delete it and use Avast. Have not been able to find any way of deleting the avg and it keeps on 'flashing' on the screen that it has virus's. 2 that I recall are "worm zhelatin & spyware banker 10". I managed to do a system restore but it has made no differance. She also has Avast (free version) on it which has been run both full & short scans, neither of which picked up any problems at all!! I am also unable to connect to the internet (wirelessly). She has Windows 7 ultimate on it. Any ideas?
Old Jan 30, 2011 | 02:59 PM
Labnerd's Avatar
Start the task manager by using the Ctrl/Alt/Delete buttons. Under the processes tab, look for anything with the name like win32.worm.zhelatin. Click on it one time to highlight it, at the bottom of the page click on end process. You have now turned it off only, it's still on the computer. Get on the net and download Malewarebytes, update it, and then run it. It should get rid of both.
If the task manager does not come up, click on Start, in the Search box at the bottom, type in msconfig. You'll get a box with tabs. Click on the startup tab. Remove the worm from the startup menu. Then get online and follow the above with Malewarebytes.
Old Jan 30, 2011 | 03:31 PM
birddog_61's Avatar
Also get rid of AVG and forget about Avast, download Microsoft security essentials, set it up and let it run. Run malwarebytes about every other week or once a month to catch anything falling through the cracks and call it good.
Old Jan 30, 2011 | 03:48 PM
Agent47's Avatar
There is nothing there that looks like that. Any other suggestions?
Old Jan 30, 2011 | 03:52 PM
birddog_61's Avatar
Restart and boot into safe mode with networking, download the 2 programs and install them. Run full scans of each removing anything detected, when they are done restart windows normally and run them again. Then uninstall AVG from the programs section in control panel.
Old Jan 30, 2011 | 04:04 PM
Agent47's Avatar
it will not let me connect to the net
Old Jan 30, 2011 | 04:21 PM
jbrew's Avatar
Yea, good luck getting rid of that, it's a PITA. I had to use "Revo Uninstaller".
Avira is the best free one out there IMO. I use it on everything except for the Mac. And it doesn't bug you lol.
I've had Avira on two machines since 05. Tried others , always went back to Avira.
Old Jan 30, 2011 | 04:23 PM
Agent47's Avatar
whats a pita?
Old Jan 30, 2011 | 04:24 PM
Pain in the backside, referring to your issues.
Old Jan 30, 2011 | 04:25 PM
jbrew's Avatar
birddog has good suggestions as well. I had problems getting rid of that on a machine running W7.
EDIT, btw - What wouldn't go away was a AVG 9 file if I recall. From a previous update maybe. Do you keep seeing this file in programs on C ?
Figured I'd post that, maybe it will help others to help you more. Yea , that 9 file would run after an uninstall of 10 and you couldn't get rid of the damn thing. "Revo" finally found it.
Maybe I shouldn't have interupted, my fault.
Old Jan 30, 2011 | 04:31 PM
Agent47's Avatar
I have managed to get rid of the avast (whilst in safe mode) but still unable to connect to the net. Avg is not listed anywhere in my progs!
Old Jan 30, 2011 | 04:41 PM
jbrew's Avatar
Then you good right ? Nothing poping up ?
Leave you comp on, disconnect power from your internet box and router if you have one. Then reconnect. Have you tried that yet ?
Old Jan 30, 2011 | 04:45 PM
jbrew's Avatar
These guys can help yuh, I was just throwing my experience w/AVG in there. Thinking it might help.
Old Jan 30, 2011 | 04:50 PM
Agent47's Avatar
Thanks guys, I am not having much luck, avast is off, will not let me connect to net or remove the avg & I keep getting warnings from avg fashing up on the screen. The three other pc's are working fine but god knows what she has done to this poor laptop!!
Old Jan 30, 2011 | 05:03 PM
birddog_61's Avatar
Grab a flash drive and go download the 2 programs on another computer. Transfer the .exe file onto the flash and install them on the bad pc. Run the programs and let them clean the system, then restart and try to connect to the net to get the updates and run them again.
