CEL Reset?
Old Jun 2, 2007 | 12:08 AM
CEL Reset?
Hey all.... got a quick question... it's not Ford related, it is Jeep/Dodge related...
I was driving down the road doing about 30 mph in 5th gear in my parents Compass that only has 900 miles on it. All of a sudden, out of a clear blue sky, the check engine light comes on solid. No flashing before hand...
I asked a friend of mine... and he said that it might have been because I was crusing in too high of a gear. Seems logical... because I am so used to driving high torque low end vehicles, as it makes me just want to drop in 5th all the time.
I am totally positive there is nothing wrong and I want to reset the CEL. I tried unhooking the battery, to removing fuses... and nothing seems to work.
Lemme guess... I need the OBDII reader to reset the light.
Old Jun 2, 2007 | 01:14 AM
Get it to the dealer.
Old Jun 2, 2007 | 01:39 AM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
With only 900 miles I would do sqwat, except take it back to the dealer.
Old Jun 2, 2007 | 02:03 AM
ian51279's Avatar
Same here. There's a reason for warranties.
Old Jun 2, 2007 | 12:25 PM
If it's running smooth at 30 mph in 5th, and doesn't lug, ping, or vibrate, there's no reason why you shouldn't do that. I fail to see why that would trip a CEL.
Old Jun 2, 2007 | 02:14 PM
chrism9232's Avatar
is the gas cap tight?
Old Jun 2, 2007 | 03:35 PM
Quintin's Avatar
It's under warranty, let the dealer worry about it. It could be a code for a more serious future problem, or it could be something silly like an evap leak.
Old Jun 2, 2007 | 05:37 PM
I borrowed my friend's reader... I nabbed two codes:
1. P0335B
2. P0016
From what I've Googled:
1. P0335B - Crank Sensor
2. P0016 - Crank and cam out-of-sync
Old Jun 2, 2007 | 07:40 PM
PSS-Mag's Avatar
What did the dealer say?
Old Jun 2, 2007 | 07:56 PM
Dealer wasn't open. I was anxious to see what codes it was throwing. I did not clear them so when the dealer opens on Monday they will be able to diagnose them accordingly.
Old Jun 2, 2007 | 08:06 PM
PSS-Mag's Avatar
Just on the side of percaution I wouldn't tell them that you read the codes. Besides the fact that it will be interesting to see what they tell you it is.
Old Jun 4, 2007 | 11:38 AM
The Compass needed a software revision update...... but those codes were for the camshaft synchros... go figure.
Old Jun 4, 2007 | 11:39 AM
PSS-Mag's Avatar
Well it's a good thing you got those updates then!
