Ringtone maker HELP PLEASE!
Old Mar 20, 2007 | 12:41 PM
The professor's Avatar
I'm not sure If I'm just stupid or what but it seems like you have to be a genius to work some of the ringtone makers that i've tried using. If anyone knows of a EASY to use ringtone maker please tell me I replace my Razr with a samsung SYNC yesterday and I'm looking to make some new ringtones. I've always bluetoothed all of my ringtones from frineds but I guess I'm the only ones who wants a george strait ringtone lol. any help is appreciated.
Old Mar 20, 2007 | 02:24 PM
Jaron2846's Avatar
Try this link http://forums.mobiledia.com/ These forums are full of info.
Old Mar 20, 2007 | 06:10 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Go here http://audacity.sourceforge.net/download/ to get audacity, then go here http://lame.sourceforge.net/index.php to get the Lame mp3 encoder. It's just called Lame it's not actually "lame", it's necessary to export as mp3...
Ah what the Heck might as write a guide.
Step 1. Go to Edit>Preferences>File Formats
You should see MP3 Export Setup.
Change the Bitrate to 24. (You should only have to do this once, because it will remember the setting from now on. But it's the most important step.)
Step 2. Load the song you want to edit
Step 3. Select the portion of the Mp3 that you want to make a ringtone. 40 to 55 seconds. Anything more is a waste (because your voice mail will kick in.)
Step 4. Edit>Trim or Cntl+T. This trims your song down to what you want.
Step 5. Click on the song name in the edit window, a drop down menu should appear.
Step 6. Set Sample format to 24=bit (When you change this it take your computer a few seconds, to refresh)
Step 7. Set the Rate to 16000hz (This is just below where you set the sample format. (When you change this the song will be really slow, so we need to speed it up again.)
Step 8. Highlight the entire track, Click and drag. (It might help to zoom out a little bit. (under the view tab or Ctrl+3)
Step 9. With the track highlighted go to Effect>Change Speed
Change the percentage to 175% (You won't be able to select change speed if you don't have your track selected.) Wait for your computer to process, check your playback, should be playing the right speed now.
Step 10. Go to the Track name drop down window, and select Split Stereo Track.
Step 11. (You have two tracks now, one for the Left and one for the Right, so they need to be combined into one mono track.) Go to the drop down menu for each track and set them to Mono.
Step 12. File>Export Mp3 (You should get a warning saying the the tracks will be mixed down to a single mono channel. This is good.) Name your Mp3 and click the save button.
Step 13. Go to where you saved your file and right click & check properties. Your file size should be somewhere in the range of (100K to 180K) Depends on how long your track is. If it's larger than 250K you did something wrong. Go back and re-follow the steps.
Your done, follow the intructions on where your suppose to place track on your phone.
Enjoy your new tunes..
__________________________________________________ _________________________________
LG
32kbps, 22050 Hz
You should be listening to ring tones on your phone in about 30 mins!!!
Old Mar 20, 2007 | 06:24 PM
JTDEERE's Avatar
Which one did you want? I have Craig Morgans "Redneck Yacht Club" on my phone.
"i'm meeting my buddies out on the lake
we're headin out to a special place..."
