Bluetooth help
Old Nov 8, 2006 | 11:09 AM
SlammaJamma's Avatar
Bluetooth help
Im pretty sure my laptop has Bluetooth. Im trying to send something from my phone to it. Where can I look on my computer to find what my bluetooth address is? Im not 100% sure it does have bluetooth but Im pretty sure. Thanks.
Old Nov 8, 2006 | 11:20 AM
akheloce's Avatar
First of all, right click on "my computer"(if you dont have it on the desktop, you can right click on the one in the start menu) click "properties" click the "hardware" tab, then click "device manager" In the list, you should see if you have BT on your PC. If you dont see the word bluetooth, you dont have it. If you see a yellow exclamation point with the word Bluetooth, you need the BT drivers from the manufacturer.
If you do have BT installed on your computer with the little blue icon showing in device manager, then you should have application software showing up in your taskbar that will have a connection wizard, or something to that effect that will walk you through the process.
Old Nov 8, 2006 | 09:43 PM
Thanks buddy Ill check it out.
