Traction Bars, HOW TO ?
Old Nov 26, 2001 | 01:50 AM
Probleminfected's Avatar
Question Traction Bars, HOW TO ?
how do i install traction bars, and how easy is it ?
thanks
Davey
Old Nov 26, 2001 | 08:16 AM
LIGHTNINROD's Avatar
Call or email Jay Lincoln about his Truck-Traks or look at his profile/web site. They bolt right on--don't even have to jack up the truck.
Dan
Old Nov 26, 2001 | 08:23 AM
Don's Bolt's Avatar
The caltracks you have to remove the spring press out the front rubber bushing and install a metal bushing. Then reinstall the spring and replace the U bolts and put on the new spring bracket.
The JDM bars you have to replace the U bolts, replace the spring bracket, and drill 3 bolts on each side of the frame.
Truck tracks are the easiest to install, followed by the JDM bars, and the caltracks are the hardest to install.
Old Nov 26, 2001 | 01:34 PM
beefcake's Avatar
jay's truck traks are so simple even i can install them
Old Nov 26, 2001 | 10:32 PM
Jay Lincoln's Avatar
probleminfected, the Truck-Traks that I manufacture can be installed in about 25 minutes with a 3/4" wrench. Just like Lightninrod said, you don't even need to jack up the truck.
Click on the link below, and you will be able to see them on my website.
Old Nov 26, 2001 | 11:24 PM
whats the proformance difference between them ?
Old Nov 27, 2001 | 08:52 PM
That's a good question. I don't know anyone that has done a back to back test on the three different bars. I know that Sal at PSP has run both the Caltraks and my Truck-Traks. He might be able to better answer the question
