View Full Version : Electrical Systems
- 1996 F-150 PCM Help!
- 1999 F-150 need help on aftermarket cruise control
- Not a F-150, but a Mustang question.
- electrical problem
- ever felt like a a**?
- PRNDL display in cluster with center shift...
- Need Electrical Help
- Cruise Control died
- help power sliding rear window
- door chime with key OUT!
- Fog light out.
- 7-pin trailer connection
- ECT gauge inop...
- 1999 F150 erratic gauge cluster; inop
- 97 F150 fuse blows that controls odometer, gauges and ABS
- drivers seat, mirros and pedals not working
- Cruise Control Servo
- brightest headlamp replacements?
- Back up lights
- phone set up
- Slow A$$ Blinker
- alarm
- No start ...Please help
- No electric power at all.
- dead battery and clicking. help me out!
- '97. No power to map lights.
- Auto On headlights stop working.
- 04 f150 antenna wire replacement
- Seatbelt chime on my 04 screw
- Stretched fuse holder
- Help! Aftermarket power locks
- lights behind the grill?
- LED's In the A/C vents
- driving light problem
- ABS problem on an Oldsmobile-Help!
- Airbag Light
- Gauge cluster swap
- Ford remote start problems
- Rear park sensors
- Need Electrical Connector Pin - Where to get it?
- Moonroof OJT Required???????
- Gonna get some mirrors w/turn signals!
- Pass Window is stuck down!!! Yikes!
- Coin holder wires?
- oem vs. aftermarket remote start
- 04 f150 lariat no cruise control
- What to do
- Why is my fuse blowing???
- Installing Keypad on 2008 F150
- ABS light came on, turn signals/brake lights went out
- Ignition Switch Removal
- 2004 FX4 Gauges not working after started
- Noise/LED bulbs/ Help Please
- Need help! HID's causing static in the radio.
- LED's as front daytime running lights...
- Trailer light Q
- 98 F150 Engine wiring?
- v6 to v8 conversion
- '04 f150 No power all of a sudden...
- Ignition lock remove w/o key
- heater controle acting up
- end of shifter?
- Daystar light bar for 2wd
- 99 F250 LD Passenger window failure
- 88 F-150 5.0 fuel elec. prob. pour gas into TB runs fine, plenty pressure at rail?
- Rear Slider?
- wipers not working
- Wiring harness under dash
- Dash thermometer issue
- trailer plug wires
- Hazard Flashers Not Working
- LED Bulbs
- alternator issue
- Wiring diagrams needed
- cruise control / door lock question
- Door Lock actuator
- HID lights
- RKE Help
- Keep Blowing OD Fuse
- Car alarm info requested
- windshild wiper problums
- Need fuse block numbers for 97 F150
- power windows and door locks not working out of blue ?? any help ???
- P0231 Fuel Pump Secondary Circuit Low help needed
- Lights mounted. NEED POWER!
- Very unique problem...
- Rivals HID
- Removing Central Junction Box
- 08 alarm help please
- Gauge Clusters
- Intermittent Odometer - 2004+ models - Help Needed
- Cruise not working after recall installed.
- Replacing RKE module
- Looking for some Part numbers
- Passenger brake light out, but directional & hazards work
- Factory Remote Start Help
- Firewall Passthrough
- Compass Failure
- Truck wont start 'sometimes' !!!
- power window problem
- One Touch Window Down
- power window.
- Darn Power Windows
- Cruise not working at all
- f150 04 silverstar???
- Windshield Wiper Problem
- Installing Automatic Headlights on 04+ F150's?
- help wiring
- Wiring in wheel well??
- Replacing Over-drive lockout switch
- 2008 lincoln headlights
- battery light is on and draining battery
- OBDII plug not working with scangauge2 plugs in
- driver wiondow goes down but not up
- LED Courtesy Light wiring?
- can I eliminate my PATS key
- Need help desperately!!!!!
- Aftermarket/OEM Cruise?
- cruise control only with lights off
- Added cruise control, was satisfied.
- Mark VIII Fan Install
- How do I install Pro Comp Explorer 100 6" lights on my Westin Bull Bar?
- Auto down no longer works on window
- Hard wiring LEDs to interior dome switch
- Adding backup lights
- Power lock motors...
- Electrical Window Failure
- Bill Howard
- How do you test a GEM Module
- Auto Locking A.R.E. Truck Cap Wiring HELP!!!
- lights on front bumper???
- 2008 F150 fuse box
- 04' F150 backup sensor
- Quick Question!!!
- Air Bag Light on 04 F150
- Scangauge - who is interested?
- Truck wont start
- Fuel gauge wont work
- Urgent, car wont start after gauge replacement.
- Mirror Help
- Does anyone know what this is attached to my hood? looks like a Sensor of some sort.
- keypad lock on door
- turn signal
- switching climate control
- 97-03 mirror switch work on 04+ models?
- Battery woes
- Electrical Gremlins in Starter, Dome Light, Tachometer
- Door Molex Connector
- I need help with my map lights
- door lock
- Hit a deer today, need a new foglight housing!
- Door Connector
- electrical issue with wipers and 4x4
- Gauges not acting right
- 2008 F parking lights
- Passenger door courtesy light lens/cover p/n?
- Starter Kill Overkill?
- odb readout
- no gauges
- How Do I Replace A Clockspring?????
- Engine coolant temperature sender wiring
- Screwd up windows
- Power windows
- Fuse Relay Question
- Intermittent AM Radio...
- Airbag light IFC 18????
- fog light mod help
- No Brake Lights... HELP
- double din screen
- Need connector for my 2005 F150
- Need help
- electrical issues
- 1997 Power Window
- no dome lights wipers not able to shift
- Wiper LInkage...Getting it back in?
- Remote Start install, door pins?
- HIDs in PIAA driving lights
- What type of guages would you install?
- Keyless Entry pad?
- Ding Ding Ding Ding Ding
- 2 quick questions for efan install
- No pass. side turn signal with lights on
- Pin/Terminal Extractor tool
- Battery won't stay charged
- ignition(key)switch
- Disabling odometer *not what you think*
- Question about rear windows in screw...
- Lights not working while turn signal is working @ trailer hitch connector
- '05 fuse - wrong amp?
- Wiper problems
- New Gauge install
- Airbag light
- Just a question:
- Where to get new MAF
- DRL and relays
- Electric side mirror problem
- Check Engine Light
- Why would my Ignition Switch Fuse blow? Other problems now arising...
- 04 F150 Problems
- Dark instrument cluster
- When it rained, it poured
- Installing a DEI 1100f need help.
- interior lights, wiper/washer, windows all inop, 98 F150
- power windows and locks?
- Gear Needle in Cluster Stuck
- Power Mirrors
- rear break light/blinker issue
- 2004 F150 airbag code 42
- cruise control not working right
- window wont roll down. HELP!!!
- Dash light blinking
- Fan Conversion????
- power seat wiring diagram
- Acts like dead battery, but it isn't
- Help with dim headlight!
- Keeping Battery Charged
- What's going on?!?!
- dead foglight
- Air bag light
- odometer backlight on 05'
- Body Security Module
- 00' f150 wiper doesn't return to normal position?
- courtesy lights
- big 3 upgrade...need help...
- Simple Antitheft
- '05 cruise control not working
- 2004 airbag
- power locks acting crazy
- Pass side wiper misbehaving
- Airbag
- 9004 Bulbs same as H13?
- headliner compass
- Daytime Running lights Removal?...
- Question?
- Power Mirrors
- Door Dome Light Question?
- Adding second battery
- Air Bag Light
- Is Compass located in rearview mirror?
- Outsid Temp Display 02 F150 Screw
- 98 F150 power windows
- Changed speedometer cluster now wont start
- Tail light Wiring Diagram please
- Mini Message Display
- ABS Fuse location
- Automatic Headlight Sensor
- fog lights
- Remote Start Problem
- Theft Light Blinking
