View Full Version : Wheels, Tires & Brakes
- tires
- park brake adjusters
- Problem Bleeding Brakes on Expedition
- 2004 rims fit on 1999 F-150?????
- Spare tire lock
- Tires and Lift?
- finally got the new cooper stt
- Did Front Brake Job, now ABS stuck on
- anyone use wheel spacers?
- claws vs. radial claws
- Anyone seen or heard anything about the new ProComp X-Treme A/T Tire??
- Centerline Rim Info
- parking brake assembly fell apart!?
- Hub switch, '01 five to '04 six lug?
- Is my dealer being honest about my rotors?
- Nitto VS. BFG
- 2 Quick Questions
- Chamber/Caster Bolt Kit Also on Suspension
- 20's on my f-150
- Still haven't decided? 4 for price of 3 Pro Comps?
- I need new tires...help me!!
- Question for Scott 7065
- mickey baja claw, will they fit?
- 1715 tuning
- 22s on a 2005 4x2 Supercrew
- Tire size for a 2004 crewcab 4x2?
- 20" wheels and 33's
- 17" to 16" rims
- Brake Job Of A Lifetime
- question on wheel offset - 04 fx4
- ABS Light
- will these fit
- looking for 22" wheels for superduty
- 315s on factory 17x7.5
- HEavier Duty Brakes
- E-Brake Slack
- 33x12.5 R15 Pro Comp Tires
- fabtech lift w/ 3 in. body NEED HELP
- Pro Comp Tires?
- 17" 7 lug wheels Available
- Big wheels w/ meat
- Abs Light
- 8 inch wheel + 33x1316 =?
- Eagle 186's
- Is it too close?
- tire question
- A Question!
- SVT rims on 04 f150?
- Wheel Bearings
- ABS Light, Sensor fixes it?
- Probably a stupid question, but.......
- How do you adjust brake pedal for left foot
- Master cylinder fluid level
- new tires
- High Pitch Squeal
- Will these Lightening wheels fit my '99XL
- 2004 FX4 Tire Wear
- 275/65 /18
- 00 Lariat 4x4 biggest tire size on stock wheels?
- 10" or 12" wide wheeel/tire recommendations
- 265/70/17 LT's on 00' Lariat wheels - Pro's, Con's
- can i fit 285/75R16's on my truck?
- Crazy Problem
- Bolt Pattern
- size mixing
- Wow!
- Leveling Kit for '98
- Disintergrating Rotors
- Please help me replace 01 studs!!!!
- BFG Rugged Trail T/A
- Need Weights of Tires and Rims for these sizes
- Just got new rims, now tires???
- Best Size for 05' w/level?
- Backspacing...
- 2004 rotor problems
- Biggest fit on stock?
- Selling my 18" Billet Specialties WITH Toyo Proxies For $800/obo
- 32x11.5R15?
- lets see your trucks' shoes!
- Tire Question
- $$ to ship tires??
- Pit Bull Tires?
- anyone try to order BFG 285x65x18 tires recently???
- Hanging Spare Tire ?
- Looking for some Knock Off Caps 4 my new wheels
- F-150 7700GVW 4x4 Brake Parts?
- putting on the ebc's
- 2001 F250 Rotor
- Need Help on Choosing Wheels & Tires
- Leveling Kits Help!!!
- Need pics of wheel/tires for 04 FX4
- front wheel abs upgrade?
- BFG All Terrains
- Why did Ford switch sizes?
- Weld outbacks
- Pro Comp MT's???
- Any 7 Bolt Rims Availiable
- Weld Eve 22's PITTING
- Got the shakes!
- Wheels & Tires picture post???
- wheels and tires for 03 f150 flareside
- Servicing Brakes
- Boss Wheel opinion
- brake pedal does not come back up
- ABS wires corroded...must replace entire module???
- squeeky brakes without pedal depressed
- Rotor replace
- Need input for wheel repair.......
- My Crew On 20s
- Lugnut problem (Explorer/F-150/Police Interceptor owners with center caps, rangers 2)
- Need 1 Tire
- Lug Nut sizes?? Again.
- Help with ABS or whatever problem with brakes
- wanting to trade for FX4 wheels
- New Ford F150 Truck Set of Tire & Wheels 17" Rims
- flat baby moons
- NITTO or TOYO??
- 16.5?
- Speedo Recalibrating itself?
- Tire clearnce on2000 F-150 SC FLARESIDE
- ? for those with terra grapplers
- Help, Crazy Brake/Power Steering issue
- Has Anyone Tried The New Torsion Lift Keys Yet?
- Adjusting Rear Drums
- 18" 2005 F250 wheels
- Brake and ABS lights?
- Help!!!
- which tires
- Quick question on torsion bars!!
- Will a 99-up lightning wheel fit on my 93?
- Can you put on 33s with no lift
- ABS light finally OFF
- buying tires online
- Same Diameter?
- Bigger tires?
- Opinion on wheels?
- Shakey Ride
- My wheels are an impossibility
- Original Tires
- dragging brake
- Perfect Fit???????
- Perfect Fit????????
- Eagle Super Finish
- ABS light comes on when towing
- 02 SCrew Lift Blocks
- Hankook Tires...
- '02 FX4 SCrew Tire Size
- 12mm/14mm studded rotor question
- New cooper STT
- hummer tires
- tires
- What will fit
- Tires For 2002 250 Sd 4x4
- 4 WABS help needed please
- Will these tires fit my stock rims?
- Help for faded/oxidized wheels?
- lift and tires
- What fits with daystar leveling kit?
- American Racing Teflon rims
- will it fit??
- How to tell when RTS's are worn out?
- ? about BFG All-Terrains '02 FX4 SCrew
- 12mm studs/14mm rims?
- 255/70/16 get better mpg's over 235/70/16?
- Tire Size
- Help with Question...
- How wide would it be?
- Should I change my computer program?
- ? about used tires & wheels
- Just want to make sure these rims and wheels fit
- first timer
- squeak when applying brakes (interior)
- ABS light on
- new tires and wheels
- 16" Wheel on a 04 f-150
- 22" Rims
- Tire & Wheels & Lift ???
- Where to get 35s and rims
- 12mm vs 14mm
- NEWB question
- something besides good years?
- Largest tires without a lift?
- alignment kit?
- help on tire fitament
- Lightening wheels on '99 F150 XL
- Biggest Tires avalible for stock 18's
- 35's on 04'?
- I Need Help From Someone That Knows...
- 285/75/16 vs 255/85/16
- lug pattern on '00 F150
- What size tires would have came on my 98 F150?
- 33/12.50 on a 17.5 rim
- Gear ratio question?
- pad & rotor combo?
- Switching from 18" to 17", need advise
- Tires on the standard rims? Help!
- Procomp opinion
- ABS not working with new sensor PLS. Help!
- Still looking for a price on Cooper S/T
- 7 lug 17" wheels
- Wheels
- Need some HELP!
- Wanted: 315/75r16d
- Red Dot On New Tires???
- MB Motoring wheels?
- Help me pick some wheels
- Just installed some 20's
- very nice
- 20" Wheels/MPG
- 04 fx wheels on 05 XLT?
- Need advice on wheel spacer
- tan truck black wheels
- Wanted: 265-70-17's
- backspace on 2001 supercrew
- What rotors for Raybestos QS ceramics?
- Rear brake / rotor questions
- Helo Maxx 6
- Wheel/Tire package
- Torque Specs 2002 Lightning
- What ply tire should I get?
- Load range letters? Need help!!
- Stock 16" wheels?
- How big can I go?
- Maybe the wrong place to ask
- Better off with A/T or M/T
- 285/70/17's or 275/70/17's???
- New T/A ko's and mileage dives
- what size are the 2000 f150 5 spoke wheels?
- Looking for FX-4 Rims
- Looking For FX-4 Wheels
- Ford jacks, throw them away....
- Wanted: 285/70/17 All Terrains
- cost of replacing a stud
- will it fit?
- Spare Tire Winch
- Tire sizing help please
- lugnut sizes on 1998 ford f150 wheels
- For Kanter to ponder on
- Praise to Cooper tires!!!!
- Im thinking about getting rid of my billet specialties
- New Shoes
- New Shoes!!
- Emergency Brake mount loose!!!
- 1999 F150 ABS Light
- e-brake light on when vehicle off
- Best MT or AT tire?
- Cooper ST's?
- bfg mud terrains
- Can This Wheels and Tires Fit????
- Ground clearance with low profile tires
