F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   F-250 / Super Duty / Diesel (https://www.f150online.com/forums/f-250-super-duty-diesel-38/)
-   -   Will 315's fit stock wheels (https://www.f150online.com/forums/f-250-super-duty-diesel/96495-will-315s-fit-stock-wheels.html)
Bob's F150 Nov 11, 2002 05:48 PM
I was wondering if 315's would fit on the stock SD wheels. I think I saw a truck running this setup.
Mach1 Nov 12, 2002 04:59 AM
Yes, you can put just about any tire on any wheel...
Word of advice, just because it is done, doesn't mean it is safe to do...Some tire places wont sell you any bigger tire then what comes stock, this tire IMHO is too big for a stock 7" rim, plus the fact they wont wear right...Plus the insurance companies frown on this if you are in a wreck...
The rule I was under and go by is 2" width over the rim width...so a 9" wide tire is about as wide as it will go safely...
I know the SD looks mean with the wider tires, You might consider going with the 295/75's..IMHO
Bob's F150 Nov 12, 2002 06:57 AM
I can get a good deal on some wheels and tires for about $880 shipped to my door, but I would need to sell my existing wheels and tires. I did see that truck again and I do remember that there seemed to be a lot of wear in the centers. And they did look way to big for the wheels. I could post them in the classifieds here but in the past there was a lot of tires and wheel in there.
Mach1 Nov 13, 2002 05:56 AM
BoB..tires and wheels...are cheap..knock-offs
Just be safe about your selection, plus you want to be satisfied cause they are going to be with you a long time..
Not trying to put down the 315's...just spend the money and buy the right rims, do it right...
Stan Wright Nov 13, 2002 03:36 PM
I ran 315/75 tires on the factory rims for several months after I lifted the truck. I didn't have any problems.
http://www.eurekaboy.com/f250/truckpix2.htm
About a month ago I got new 16x8 wheels. I will say the new wheels look and handle better.
http://www.eurekaboy.com/f250/newwheels.htm
Mach1 Nov 13, 2002 10:10 PM
Stan--wont those tires work on 10" wheels, what are the widths on those??I would think it is around 10" thread width???
I usually try to match the tire to wheel 1 to 1...10"tire to 10" wheel..
But, like you say, you can run them...
Stan Wright Nov 13, 2002 10:25 PM
Yes, you can run those tires on 10" rims. A 10" wheel is probably the most popular choice for 315/75 tires (same as 35x12.50R16). I like the tires to stay in the wheelwell as much as possible because I have a 350' gravel driveway and I don't want my paint to be chipped up. That's why I've stayed with 7" and 8" rims.
altec Nov 13, 2002 10:47 PM
YES YOU CAN PUT 315 w/o any problems; BUT it depends on what stock rims your truck came with.
I've got a 2000 SD-Crew Cab - V-10, 4X4, "Lariat" package. Those models came with an 8" rim. To all the pundits out there, 'Yes, the guys at Discount Tire and I measured them'. I'm running 315 75R16 with no problem..... Truck has a 4" BDS Lift....
m2
Bob's F150 Nov 14, 2002 05:47 PM
I have the deluxe alum. When I got the 285's put on these wheels measured at 7". I have been looking for steel wheels since I will be doing some wheeling and steel usually is less likely to be damaged and is easier to repair. But I have had no luck in finding any 8 or 10" wheels in steel. Any suggestions?
altec do you have any pic's?
Mach1 Nov 18, 2002 05:30 AM
So altec, I have 2000 w/lariet wheels on my truck, so the PSD uses different wheels then the V10??? They used less wider wheels on the PSD???
I believe they all came with 7" wide wheels...
And a 12.5 tire on a 7" can be mounted(yes), but is it the safe thing to do..Not in my opinion...
firedude26 Nov 25, 2002 02:42 AM
I have 315 75 16 on mine with Lariat wheels and they fit fine , ride fine and look fine.
Bob's F150 Nov 25, 2002 10:41 PM
OK, how about 295/75-16 BFG All terrain T/A's They are only 1" shorter and 1/2" narrower than 315's but they are spec'd for 7.5-9.5" wheel. My 285's are spec'd for 7.5-9" and they are doing well. With the 4" lift I do want more rubber but I also like my OEM wheels. If I did this, could I keep the 285 spare I have, or should I go with another BFG. I hate to spend the extra money for something that sits under the truck. I dont have ls and I figure I will go to the closest place I can get it fixed.
Mach1 Nov 26, 2002 03:23 AM
Bob..I understand about the wider tires and they look sweet on the trucks...The drawbacks are decreased fuel economy, and you get abnormal wear on them because you dont have the rim for them...There are alot of people out there running them...
The 295/305 is a size that people use...the spare would work with these...I wouldn't buy another tire just for the spare, which I dont use mine...
If you want the 315's, then do it...I am saying that I would not do it...Alot of people have them and say its no problem...off road they work well...They sure do look good, and I have not seen too big a tire on these trucks yet(have seen 44" on one)..
Bob's F150 Nov 26, 2002 06:27 AM
I bought a set of 315’s from Nebraska tire. They were new take off Wild Country’s. I got them for $61.50 plus $45 Freight. A good deal except they had to scrub the lettering off both sides because I guess Les Shwab has an exclusive on these tires from what I am told. Other than where the lettering was they look great. They have 18/32 of tread which is what they are rated at from the factory. I plan to mount them to new 8” wheels since the 7” are not approved for these, but 8” is. I just with they didn’t have to scrub the lettering off.
Mach1 Nov 26, 2002 09:18 PM
Are these 12" tires, and if you are getting new wheels, I ask if the 10" wheels might be the way to go, if they are not very much more...I guess it also matters if there is room(lift kit)???
